Join TDPRI Today
Water slide decals question...
Discussion in 'Tele-Technical' started by Phil_tre, Mar 20, 2011.
  1. Phil_tre
    Phil_tre Tele-Holic
    677
    Oct 31, 2010
    Eastern Canada
    Hi !
    I will soon have all the parts to finish my "partcaster"
    and I would like to put a custom water slide decal BUT
    I don't want to spray clear over my new neck that is
    already finished... Will it work ? will it looks clean ??
    Thanks !
    Philippe
  2. RussBert
    RussBert Tele-Holic
    905
    May 11, 2005
    Connecticut
    Decals are VERY delicate and will flake off unless it's covered with some clear finish
  3. mellecaster
    mellecaster Former Member
    There are a lot of Old guitars around with their Decals still intact, that would challenge your statement.
  5. txcoach5
    txcoach5 TDPRI Member
    9
    Feb 21, 2011
    Spray the decal with several coats before you cut it out, then apply. Ive done two this way, then sprayed one after I applied and one did not. They both turned out well.
  6. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    I don't find this to be true at all. I put decals on top of the lacquer all the time without any negative consequences. No flaking yet.
  7. Drunkinminer
    Drunkinminer Tele-Holic
    889
    Feb 3, 2008
    Same here
  8. LoudTele
    LoudTele Tele-Meister
    366
    Sep 12, 2009
    Wisconsin
    Why not just tape off and spray the headstock? That's what I do.
  9. Thighbanez
    Thighbanez Tele-Afflicted
    Aug 5, 2010
    delMARva
    It doesn't always come out evenly...like with my headstock...
  10. nadzab
    nadzab Friend of Leo's
    Mar 23, 2009
    New England
    Undisturbed, a properly-applied decal with no overcoat won't come off...but if something should scrape against it, there's a strong possibility that it will be damaged.
  11. whodatpat
    whodatpat Friend of Leo's
    Jul 21, 2007
    College Park MD
    From personal experience, let it dry for a day after you apply it, before you spray it. I got some nice blushing. :(
  12. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    This one managed to survive 59 years. I guess it never got scratched.
    The point is, if it is properly applied, on top is just fine. If you scrape it hard enough to remove the decal, it would have scraped it hard enough to damage the lacquer as well.
  13. JBennett
    JBennett Tele-Afflicted
    Jun 23, 2008
    Cold Spring, NY
    While experimenting with my own waterslide decals I've applied and removed decals that were applied on top of finishes. They are pretty durable.
    I always coat my decals with a couple coats of lacquer before they are applied so that helps. The decals are much more fragile when they are uncoated.
    It took a lot of picking and scratching to get them off and I had to re-buff the surface below before putting on a new decal, so yeah, they are delicate if they come in contact with a sharp surface in the wrong place/wrong time, but can be pretty tough once applied.
  14. Rhomco
    Rhomco Friend of Leo's
    Oct 8, 2004
    DFW, Texas
  15. piece of ash
    piece of ash Friend of Leo's
    Dec 29, 2010
    Sugar Land, TX
    Cool website Rhomco...
  16. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
  17. JBennett
    Jun 23, 2008
    Cold Spring, NY
    I've heard that that stuff is just repackaged "white vinegar".
    I have a bottle of decal setting solution made by Walthers (or bottled by walters) the model train company. It says the ingredients are:
    "Methoxy-2-propanol, methoxy-1-propanol"
  18. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    Ive heard the exact same thing. Ive talked to some model train guys, and they told me just to use white vinegar.
  19. nadzab
    Mar 23, 2009
    New England
    There are different grades of setting solution...the ones that are made to suck the decals onto contoured surfaces (e.g., rivets and panel lines on an airplane's skin) are more potent than just vinegar...they are chemical-based...but probably overkill for applying a decal to a headstock.
