warmoth neck adjustment
Discussion in 'Tele-Technical' started by valriver 1940, Mar 5, 2012.
  1. valriver 1940
    valriver 1940 TDPRI Member
    80
    Jul 17, 2007
    winnipeg mb. canada
    what tool and size is used to adjust the heel end of a warmoth neck?:?::?:
  2. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Jun 24, 2006
    Fort Worth,Tx.
    Without you showing a picture, I'd say a screwdriver of the appropriate size and style.
    I have a Warmoth Vintage neck and it takes a flat blade screwdriver.
    Some people use a paint can opener with a flat blade at a right angle so they don't have to remove the neck to adjust it.
    Just look at it. Should be easy to tell what you need.
  3. valriver 1940
    80
    Jul 17, 2007
    winnipeg mb. canada
    thanks for the reply! tried a few flat scewdrivers and found one that fits. thanks telex 76!
  4. valriver 1940
    80
    Jul 17, 2007
    winnipeg mb. canada
    by the way the adjustment has no slots just a round opening. looks like a hex wrench should fit but could not find the right size. a flat blade did jam in it, able to use.
  5. valriver 1940
    80
    Jul 17, 2007
    winnipeg mb. canada
    after much tool eliminations i found the right tool for my neck trustrod adjustment. it is a 7/32 " hex key. it is a perfect fit. so keep that in mind fellow tel partcaster builders using warmoth necks with a round heel adjustment opening.
