Join TDPRI Today
Want to use EQ from one amp for a second amp?
Discussion in 'Tele-Technical' started by tmlfan72, Apr 6, 2012.
  1. tmlfan72
    tmlfan72 TDPRI Member
    93
    Aug 20, 2011
    Ontario
    So I can connect two amps together using a Y connection. Haven't tried this.
    But I only want to use the second amp for graphic eq and contour controls.
    I'm assuming that if I connect two amps via the Y connection the eq from that amp will not effect the second amp. Thats kinda what I want to accomplish.
    Is this possible. or should I just by an eq pedal?
    Any ideas?
    Thanks
  2. KokoTele
    KokoTele <img src="http://www.tdpri.com/gifs/vendor.png" /> Vendor Member
    albany, ny [not chicago]
    No, you can't do what you want to do, not without extreme modifications. Get an EQ pedal or a rack mount EQ for even more control.
  3. tmlfan72
    93
    Aug 20, 2011
    Ontario
    Good to know.
    Glad I asked before I murdered my amps.
    Thanks KokoTele!!
