VOX Night Train 15 no power HELP plz
Discussion in 'Amp Tech Center' started by Rumzdizzle, Apr 2, 2013.
  1. Rumzdizzle
    Rumzdizzle Tele-Meister
    KC MO
    So I came home from work at 1130 pm and was gonna play for a bit before going to bed and when I went to flip on the amp it was already on. The last time I had played had been the day before so it had been on (on standby) for at least a day and a half. The jewel light was not on and had no power.
    I checked the fuse and it was burnt on the side so after going to many stores to get a fuse (1.25 amp time delay) I came home and it blew the fuse again in less than a second. Tried another one and the same thing happened... The light came on for a second and it blew the fuse again.
    I understand that it could be the power tubes or one of the transformers, but how do I narrow it down?.. I don't want to spend a small fortune repairing it because a new mercurymag transformer costs 205-235 and I don't even know how replace that.
    Clifnotes:
    No power, blowing fuses...
    How do I find the exact problem?
    Any alternatives to mercurymag transformes?
  2. davis1676
    davis1676 TDPRI Member
    Hooks, Texas
    did you get this fiqured out?
  3. Harleyjon
    Harleyjon TDPRI Member
    England, UK
    Unfortunately if it takes out the fuse in standby mode the transformer may well be faulty. Usually caused by a bad connection in the mains supply, IEC plug, lead etc.
    Disconnect the secondary wires, two violet one grey and two orange, then try again with a 60Watt light bulb in series with the mains supply, that will save your fuses.
