Vox BC 108 and tube heads
Discussion in 'Amp Central Station' started by Il Belva, Nov 9, 2017.
  1. Il Belva
    Il Belva TDPRI Member
    66
    Apr 26, 2016
    Italy
    Hi guys,
    I was thinking to get a Vox BC 108 speaker for home use (not gigs nor reharsals).
    The spec table says that this cab can handle up to 15w, does it mean that I can hook up my AC15c2 to it? It would be very weird!
    Anyway I was thinking to use it with a bassbreaker 007 head that I'm going to get in the next days.
    Do you think this thing can handle 7 "real" watts for home use (I surely won't crank it up at max!)
  2. LGOberean
    LGOberean Poster Extraordinaire
    May 31, 2008
    Corpus Christi, Texas
    Huh? o_O:confused: The specs on the Vox page for this speaker cabinet says it's rated for 25 watts RMS max input. http://www.voxamps.com/BC108
  3. Dacious
    Dacious Poster Extraordinaire
    Mar 16, 2003
    Godzone
    Should be able to handle an AC15 easy. It's not a very efficient speaker, and being 8" will likely sound smaller than you're used to - but that's the point of a home speaker.
  4. Il Belva
    66
    Apr 26, 2016
    Italy
    Yep you're right, sorry for the typo
  5. Il Belva
    66
    Apr 26, 2016
    Italy
    The inefficency is a plus for home use. My problem is just psychological: it is so weird connecting a big beast like an AC15 to that cab!!!
  6. Dacious
    Mar 16, 2003
    Godzone
    Check out a few of the small acoustic amps designed for street performance - some of them have dual cone concentric 6" speakers - but can fill a mall!
    For your uses the small cab is ideal. You're right, the inefficient rating is a plus for home use.
