Volume pot issues
Discussion in 'Tele-Technical' started by holgaguy, Sep 15, 2017.
  1. holgaguy
    holgaguy Tele-Afflicted
    Apr 23, 2003
    Massachusetts
    I needed to replace my volume pot on my Road Worn recently. I like to do volume swells but with the new pot, it's impossible. It's way to stiff.
    Does anyone have a remedy for this? It's a CTS 250K pot.
    One more thing, the threaded shaft of the pot is too wide for the knob, so the knob sits higher off the baseplate than the tone knob.
    Maybe I just bought the wrong pot?
  2. tubejockey
    tubejockey Tele-Meister
    229
    Nov 25, 2015
    the bozone
    Get a can of Deoxit, spray a little in the pot and work it till it loosens up.
    LutherBurger likes this.
  3. holgaguy
    Apr 23, 2003
    Massachusetts
    Sounds like something you would use in rehab. I'll try it! Thank you. :)
  4. LutherBurger
    LutherBurger Friend of Leo's
    Oct 29, 2013
    NYC
    The threaded bushing should be 3/8" in diameter. Some are 1/4" tall, and some are taller.
    Try putting a 3/8" washer between the pot and the bottom of the control plate. That will lower the pot, and the knob will sit closer to the top of the plate.
  5. holgaguy
    Apr 23, 2003
    Massachusetts
    Yes, I finally figured that out! They are two different sizes. Duh. :)
