Voice Of Music 8810 amp
Discussion in 'Shock Brother's DIY Amps' started by bryant234575, May 24, 2019.
  1. bryant234575
    bryant234575 TDPRI Member
    Muscle-shoals AL
    Just bought a Voice Of Music 8810 amp it makes no sound tubes do not glow at all. I do not see a fuse that could be blown. Is there anything simple it could be?
  2. rangercaster
    rangercaster Friend of Leo's
    portland, or
    Start simple ... Is the power cord good ? Speaker connection ?? Tubes visual ...are they black or cloudy??? , check the pins for corrosion or misalignment ... That's the simplest ...
  3. Wally
    Tech time. The amp should have been brought up slowly on a Variac. Regardless, at this point one simply begins a rebuild by assessing the transformers. It is a given that the filter caps need to be replaced. IMHO, current should not be applied until proper tech work has been done.
  4. bryant234575
    Muscle-shoals AL
    What could I have potentially damaged by not using a variac?
  5. bryant234575
    Muscle-shoals AL
    nybody know what voltages I could expect to see on the outputs of the transformer?
  6. muswell_hillbilly
    muswell_hillbilly Tele-Meister
    Greenfield, WI
    It'll vary a bit depending on your line voltage, but nominally, you should measure 630 VAC red-red, 6.3 VAC green-green, and although not stated, I'm going to guess 5 VAC yellow-yellow.
  7. Wally
    440VDC give or take on pin 7 of that rectifier??? It is my practice to replace all electrolytics and then fire the amp up on a current limiter. If there is no short indicated, then one can go to wall voltage. That is when you can find out what you have there. IMHO, working on an amp that old without first establishing fresh power supply and bias caps is futile.
    muscmp likes this.
