Vintage Tele Neck Number?
Discussion in 'Vintage Tele Discussion Forum (pre-1974)' started by coolharmony, Jul 9, 2017.
  1. coolharmony
    coolharmony TDPRI Member
    5
    Oct 7, 2006
    New York
    All experts,
    Please let me know what the numbers of my vintage Fender Tele mean and what do the markings mean inside the neck pocket? I got this tele years ago from a friend who thought it was from 1968.
    Thanks!
  2. Ron Garson
    Ron Garson Friend of Leo's Silver Supporter
    May 18, 2003
    The serial number dates to 1968. Made at the Fullerton plant.
  3. coolharmony
    5
    Oct 7, 2006
    New York
    Very much appreciate your help with this. Would you let me know how it dates to that year and the Fullerton plant?
    Thank you.
  4. bluenote23
    bluenote23 Tele-Meister
    You can use any number of Fender serial number references (on the web or in paper form) that will give the corresponding date to the serial number on the neckplate. So your neckplate dates from around 1968.
    The stamped numbers on the butt end of your neck are unfamiliar to me and are not any vintage Fender format that I know about.
    Do you have a photo of the peghead and logo? It's not a maple cap so it is not from 1968.
    The pickguard is not from 1968 so the electrics may have been changed.
    Do you have a photo of the body without the pickguard, or with the pickguard moved so we can see the pickup routs?
    Can you see paint post holes in the back of the body?
    These things will help you to discover when your guitar was made.
  5. coolharmony
    5
    Oct 7, 2006
    New York
    The stamped numbers are original Fender numbers from the CBS era.
    Will check the things the mentioned.
    Thank you.
  6. bluenote23
    From my knowledge, if it was a later neck stamp, it should start with 13, the CBS model number for a Telecaster.
  7. brenn
    brenn Tele-Afflicted
    Dec 8, 2013
    Kentucky
    The green stamped numbers look like the 1970's number code I have seen. Not sure about the exact details of the number format, but the stamping looks normal and like plenty of other Fenders from the time. I think that style started in 1969, so not far off the 1968 estimate his friend had.
    Looking at Duchossoir's "Guitar Identification" that code should probably start with a 3 and end with a B and be 7 to 9 digits long.
    This site, that is usually a very good source, says that numbering style can go back as far as 1967. http://www.guitarhq.com/fender.html#serial
  8. coolharmony
    5
    Oct 7, 2006
    New York
  9. Hags
    Hags Tele-Meister
    115
    May 7, 2016
    Northwest CT
    I'm not an expert but the 3 on the neck stamp should mean tele,the B is nut width(1 5/8th) the rest I'm not sure of, the 0 makes me think 1970.
    Pots,pickups ect... Would tell you more
  10. Ron Garson
    May 18, 2003
    I put the serial number into this guitar dater, and that is what came up.
    http://www.guitardaterproject.org/fender.aspx
  11. coolharmony
    5
    Oct 7, 2006
    New York
