Join TDPRI Today
Vintage-spec WRHB pots
Discussion in 'Telecaster Discussion Forum' started by latebloomer, Apr 27, 2011.
  1. latebloomer
    latebloomer Tele-Meister
    159
    Feb 27, 2011
    Salt Lake City
    Curtis Novak just rewound my '72 RI neck WRHB to vintage spec for my 2001/2002 MIM Tele Custom (and wound one of his Tele-Vs at 7K for the bridge).
    I've heard conflicting opinions on the stock 250K pots. Some say why didn't Fender install a 500K for the WRHB; someone else said the 250K keeps it from being too bright. (And then didn't I see a 375K and a 1 MEG somewhere...)
    I know ultimately it comes down to my own subjective judgement on tone, and that caps play a role, too. But I'm curious if rewiring a RI WRHB changes things.
    What pots were the original Tele Customs/Deluxes equipped with for the WRHB? What difference can I expect between the 250K and the 500k?
  2. The original WRHB used 1 MEG pots for tone and vol with one .022 MFD capacitor on each tone pot.
    Don't know how this would apply to the re-issues, as they're not the same pickup, really.
  3. latebloomer
    159
    Feb 27, 2011
    Salt Lake City
    After Curtis' rewinding, bobbin modification, and replacement of steel screws with threaded magnets, it's no longer a re-issue, exactly. Which isn't to say it's 100% like an original.
    I assume the single coil of the Tele Custom was 250K and .047/.05?
  5. spankdplank
    spankdplank Tele-Afflicted
    Jan 19, 2007
    Houston, Tx.
    An original 70's Custom had 1 meg tone and volume pots and a .022 cap for both the WRH neck and single coil bridge. I have an original 75 Custom and can verify that.
  6. latebloomer
    159
    Feb 27, 2011
    Salt Lake City
    Thanks for the info, I might as well start there and see where the tone quest leads me.
  7. Telenator
    Sep 19, 2005
    Vermont
    Novak uses FeCrCo threaded magnets which tend to be very bright. Personally, I would start with 250K pots.
    The cap won't matter so much as it really only changes the "contour" of the tone pot. Not the actual tone.
    The original vintage WRHBs were wired with 1 meg pots but they used much larger bobbins and heavier gauge wire and that combination produces a very unique sound.
  8. latebloomer
    159
    Feb 27, 2011
    Salt Lake City
    When Novak winds to original specs, he doesn't use the same gauge wire? I knew the bobbins would be a compromise.
    His site doesn't explicitly say which threaded magnets he uses, but it also doesn't explicitly state what they aren't...in error I assumed rewiring to vintage spec meant he'd use the original magnets. I know they're impossible to come by, but I figured he found a stash much like Telenator did.
  9. Telenator
    Sep 19, 2005
    Vermont
    I can only assume that the use of the term "vintage spec" means he's winding the pickup to about 10.4K using a smaller gauge wire because 42 gauge, which is original vintage spec, will not fit on the smaller MIM bobbins to make a hot enough coil.
    I think that if anyone else was making pickups with CuNiFe, they'd let you know in full detail because it's "the stuff!"
    As far as I know, Telenator is the only one.
  10. latebloomer
    159
    Feb 27, 2011
    Salt Lake City
    I made some incorrect assumptions. I didn't expect a clone, at any rate. I just hope it sounds better than the RI wrhb. :)
  11. JuSteve
    JuSteve Former Member
    373
    Apr 9, 2011
    S. Central, Pa.
    I know guys like gear talk, but do you have an original WRHB for tone comparison?
  12. latebloomer
    159
    Feb 27, 2011
    Salt Lake City
    I do -- a friend has a 75 deluxe. Mainly I don't like how the RI sounds period, but also on a philosophical/whatever level, why offer a RI that is so far away from the original? Seems an esthetic (i.e., marketing) decision more than anything.
  13. vaughn
    vaughn TDPRI Member
    8
    Jan 28, 2009
    San Diego
    Hi, Would anyone here have a wiring diagram for a '72 Thinline Tele. Mine is a MIJ '91 and I can't quite figure out the wiring. It has a continuous taught bare wire that strings /grounds all the parts together and has me wondering if there is a more conventional way.
  14. latebloomer
    159
    Feb 27, 2011
    Salt Lake City
    http://support.fender.com/service_diagrams/telecaster/013-7402B_SISD.pdf
  15. vaughn
    vaughn TDPRI Member
    8
    Jan 28, 2009
    San Diego
  16. latebloomer
    159
    Feb 27, 2011
    Salt Lake City
    I don't know how to compare to a strat, and I never did figure out why some diagrams have it like this -- but in the Teles I've worked on I ground them to the tone pot itself.
