Value of a 1958 Top-Load Bridge?
Discussion in 'Vintage Tele Discussion Forum (pre-1974)' started by timmer, Nov 17, 2015.
  1. timmer
    timmer Tele-Afflicted
    I've had this bridge in my parts box for a bunch of years and have used it for a while in several guitars, but it always goes back into the box.
    Well, I'm cleaning out all of my parts that I don't need or could use, and am wanting to sell it.
    Any idea on what it would be worth?
    Here are some pictures:
    Many thanks to those that could shed some light on this.
    Edited to add:
    I thought I put this in the vintage section, would a mod please put it there?
  2. newtwanger
    newtwanger Blackguardian. Ad Free + Supporter
    Feb 11, 2007
    Quebec, Canada
    They pop up on eBay rarely asking $450-> infinity. Cheapest I saw one sell for was just under $300.
  3. Antoon
    Antoon Tele-Holic
    743
    Feb 10, 2010
    Low Lands
    It sure does not seem to have seen much use. Why do you think it is that old if I may ask?
  4. newtwanger
    Feb 11, 2007
    Quebec, Canada
    Fender only produced this bridge in 1958 and 59.
    Many of the top-loader guitars from that brief period actually had bridges with both the string-through holes AND the top loader holes.
    Note the lack of string-through holes. This is a very rare beast indeed.
  5. Antoon
    Antoon Tele-Holic
    743
    Feb 10, 2010
    Low Lands
    So it is because of the lack of string-through holes that you think it is original 1958, ok. It looks barely used to me and I recall the thread on the saddles appearing finer on old saddles, which made me doubt initially. I can confirm your info on the value, based on what I saw when I was looking for a 1950s tele bridge plate myself.
  6. timmer
    Thanks guys.
    I've had lingering questions on the saddles myself. I know they went threaded in 1958 and the height adjustment screws changed to almost 90 degrees. One of the saddles is around 90 degrees and the other two are a little less. Also the threads are courser than other pictures I've seen, as mentioned above.
    It looks like I need to start digging on the net to see when the coursness of the threads and the height screw angle changed between years.
    I don't want to misrepresent it if I do decide to sell.
    Cheers!
  7. LBUCKINGHAM
    LBUCKINGHAM TDPRI Member
    10
    Sep 14, 2017
    California
    Is this somehow still available? Haha. I'm looking for one at the moment.
  8. jazzmaster90150
    jazzmaster90150 TDPRI Member
    42
    Aug 6, 2017
    NYC
    They also used on 1960 teles and esquires even though they had string through bodies. I have one on my 1960 esquire.
  9. Dacious
    Dacious Poster Extraordinaire
    Mar 16, 2003
    Godzone
    Looks legit to me. Toploaders aren't considered an improvement to string through - it was probably a cost reduction excercise which is why it lasted so short a time. That and the slimmer neck.
    Conversely that makes them rare and arguably valuable. That is a rare bird.
  10. LBUCKINGHAM
    10
    Sep 14, 2017
    California
    And toploaders aren't considered any worse than string through either. Functionally they are the same, now you can argue they sound different, but it's hogwash and simply untrue. Scale length is the same, tuned to standard pitch so it is the same and the string stops on the same saddle in the same spot, ball ends even both touching metal. As far as feel goes, it can be ever so slightly different(due to the break angle)but no worse than a "traditional" bridge. I prefer top loaders simply because it makes restringing easier for me. No flipping guitars over or poking the string around to find the right hole like a strat.
  11. BigDaddyLH
    I wonder why Leo didn't start out with a bridge like this -- he was so focused on simplicity and ease of manufacture.
    Wally and LBUCKINGHAM like this.
  12. Dacious
    Mar 16, 2003
    Godzone
    Because the Broadcaster was built around the lapsteel he and Doc Kauffman were making and bear in mind, initially to sell K&F amps. The string-through design is a legacy of that, much shorter, neck and body and used the same pickups as Broadcasters. Even the ashtray - same concept for shielding and handrest
  13. BigDaddyLH
    Where all their lap steels string-through? I seem to remember top loaders.
  14. twr1
    twr1 TDPRI Member
    84
    Dec 15, 2016
    sonoma county, California
    Campilongo uses a toploader.
  15. PelhamSG
    PelhamSG Tele-Meister
    254
    Aug 22, 2017
    chicago
    Same knobs too!
