V1 cathode resistors?
Discussion in 'Shock Brother's DIY Amps' started by Uncle Daddy, May 13, 2019.
  1. Uncle Daddy
    Uncle Daddy Tele-Holic
    Maldon, England
    Has anyone tried altering the v1 resistor value on a 5e3; how did it change things?
    Thanks
  2. Wally
    What would be the Goal? A 5751 or a 12AY7 would be two steps of lower gain. IF a person wanted to increase gain, then rebiasing that triode with a smaller value resistor would do that...as would a bypass cap. I have never needed more gain there. Ommv.
  3. Paul-T
    Paul-T Tele-Meister
    London
    Just hopping on the same lick.... I always see cathode caps listed as 25uF, when these days the value most folks offer is 22uF.
    I presume that using 22uF makes no significant difference at all, given that especially older electrolytics were +/- 20% in any case. I see the few people that offer the 25uF value seem to charge a huge premium so to control costs was planning to buy generic 22uF. Does that sound plausible or am i missing something important?
  4. Tom Kamphuys
    Tom Kamphuys Tele-Meister
    The Netherlands
  5. robrob
    United States
    If you bias 5E3 V1 warmer you'll add a little gain, cool it and cut some gain. You won't get any asymmetric clipping because the guitar signal isn't strong enough to clip at the first stage.
    V2A is where a bias change could be productive. Putting a 12AX7 in V1 and making V2A a cold clipper could yield some interesting results (I haven't tried this) but it definitely wouldn't be a 5E3 anymore.
    muswell_hillbilly likes this.
  6. Tom Kamphuys
    The Netherlands
    I did some calculations on the gain of an (unbypassed cathode) gain stage.
    I found this (load 1M, Ra 100k):
  7. David Barnett
    But if it's bypassed...
  8. Tom Kamphuys
    The Netherlands
    it's different.
    Nice homework assignment for tonight...
