Using Ac30 normal channel?
Discussion in 'Amp Central Station' started by jc4yr, May 22, 2018.
  1. jc4yr
    jc4yr TDPRI Member
    Providence, RI
    I like you’re thinking. I’m gonna see what I can do!
  2. jc4yr
    jc4yr TDPRI Member
    Providence, RI
    Cracked the code. Shout out to everyone that just told me to turn it up!
    ellisvertellis likes this.
  3. Norris Vulcan
    Norris Vulcan Tele-Meister
    Somerset, UK, Europe
    Are your ears ringing ?
    jc4yr likes this.
  4. jc4yr
    jc4yr TDPRI Member
    Providence, RI
    A little bit. It’s on 15w mode but still loud! If it had an ohm selector I’d just disconnect one of the blues
  5. jc4yr
    jc4yr TDPRI Member
    Providence, RI
    Anyone have wisdom on an eq pedal that’ll work well? I want to mess with that too
  6. jc4yr
    jc4yr TDPRI Member
    Providence, RI
    Your wisdom is further unraveling. Had my tech look at the schematic. For some reason Vox didn't use a bright cap in this amp! that explains a lot about loosing high end with lower volume. I just got a Tone Job. I'm going to give that a test drop before i look into dropping a bright cap in.
