Two parts '54 Precision, One part Thunderbird
Discussion in 'Tele Home Depot' started by loopy reed, Feb 25, 2017.
  1. loopy reed
    loopy reed Tele-Afflicted
    Nov 14, 2007
    Nashville, TN
    Building this one for a friend, who is sending the materials. He wanted a '54 Precision Bass, but made from mahogany, with Thunderbird pickups.
    Here's the general idea:
    This won't be a fast build or a painstakingly detailed thread. We've all seen builders who are far more skilled and practiced than I am go into detail about exactly how to build a guitar, so we won't get into that.
  2. loopy reed
    Nov 14, 2007
    Nashville, TN
    Marked the centerline and outline on a Warmoth mahogany bass-sized blank
    PingGuo and Mat UK like this.
  3. loopy reed
    Nov 14, 2007
    Nashville, TN
    Cut out with my jigsaw and sanded almost all the way to the line
    Had some rough spots where I broke a blade, and another where the base of the saw started drifting and cut in at an angle. Luckily I was far enough away from the line for it to have caused too much chaos, but lesson learned.
    PingGuo likes this.
  4. loopy reed
    Nov 14, 2007
    Nashville, TN
    Routed to the template. I don't have a router table, and will be getting one after this experience. Had to use two different bits and it took 3 passes, but it's done, and pretty clean. Didn't have any tearout issues at least.
    guitarbuilder likes this.
  5. loopy reed
    Nov 14, 2007
    Nashville, TN
    Sun was up and my toys were still out, so I thought I'd try the roundover on the back. 1/2", a little bigger than the '54 recipe calls for, but that's not really something I care too much about on this project.
    I am definitely getting a router table and may look into a more powerful router to mount in it. Luckily this will be getting an opaque finish so I don't have to worry too much over the burns. Got a little tearout here and there but nothing that can't be handled.
    Arch Stanton and fortj3 like this.
  6. loopy reed
    Nov 14, 2007
    Nashville, TN
    Now it's time to get creative.
    My friend, who "ordered" this bass, will be using a Warmoth neck built to fender specs. Which is great, except...
    My templates have a square pocket, true to '54 specs, and Warmoth doesn't make a square heeled neck.
    I may use a tracing bit and copy the pocket from my jazz bass. Gonna work that out today.
    PingGuo likes this.
  7. guitarbuilder
    Mar 30, 2003
  8. loopy reed
    Nov 14, 2007
    Nashville, TN
    Spent all day figuring this one out. What I ended up doing was using a pattern tracing bit to copy the neck pocket of my jazz bass into a piece of MDF.
    Then I put the neck in to check the fit, and after lots of careful measuring was able to draw out the center line.
    Lined that up with my body's centerline, and after three passes I got it to 5/8" deep. Looks pretty good. It's just a little gappy so I'll probably glue in a veneer or two later on.
    PingGuo likes this.
  9. loopy reed
    Nov 14, 2007
    Nashville, TN
    Went ahead and did the roundover too. Did I mention this is the first time I've done all this stuff?
    Starting to look like a bass! Tomorrow I'll do the pickup routes and get started on the contours.
    Tonetele, Muzikp, PingGuo and 2 others like this.
  10. loopy reed
    Nov 14, 2007
    Nashville, TN
    I’m sure we’re all aware that in guitar building terminology “tomorrow” can mean “53 weeks later” right?
    In order to get going correctly I felt it was necessary to draw some plans, so I can work out my moves. Doing the mental gymnastics to figure out where to drill was too much work, and I’d get confused. This is my first submission for the new owner’s approval.
  11. loopy reed
    Nov 14, 2007
    Nashville, TN
    The biggest hold ups were the pickup routes.
    Thunderbird pickups have a 3/8” radius on the corners. I eventually found a 3/8” router bit and went through countless trial-and-error runs cutting MDF for templates until one day I dawned on me that a 3/8” RADIUS meant 3/4” DIAMETER.
    Duhhhhhhh
    So I did the math, glued together some chopped-up yardsticks as fences for my router base, and got after it.
    PingGuo likes this.
  12. loopy reed
    Nov 14, 2007
    Nashville, TN
    It’s just a little gappy, which is fine because we are using the nickel trim rings to hide the cavities.
    Funny how a year’s worth of agony can be solved with very basic geometry.
    Epikaster likes this.
  13. loopy reed
    Nov 14, 2007
    Nashville, TN
    One T-Bird pickup cavity template, freed from its MDF prison. I’m very thankful they’re both the same size.
    PingGuo and ModerneGuy like this.
  14. bcarter_1
    bcarter_1 Tele-Afflicted
    Looking good... I like the looks of the old p bass
    loopy reed likes this.
  15. brookdalebill
    Nov 15, 2009
    Austin, Tx
  16. loopy reed
    Nov 14, 2007
    Nashville, TN
    Starting on the pickup routes with a big Forstner bit.
    It doesn’t look like much because the pickup routes are going to be fairly shallow. I’m aiming for 3/8” depth, considering that the pickups are less than 1/2” thick and the height of the strings from the body.
    I’d much rather have the pickups a little more proud of the body than have to go back and make the neck pocket deeper.
    I also broke my router just now, so this is where we stop for a while. Was considering getting a new one anyway.
    Barncaster likes this.
  17. loopy reed
    Nov 14, 2007
    Nashville, TN
    Got a registration pin rig setup so I can do the control holes
    Already drilled from the front
  18. loopy reed
    Nov 14, 2007
    Nashville, TN
    Nice and straight! By the way this was a very difficult photo to take
    PingGuo likes this.
  19. loopy reed
    Nov 14, 2007
    Nashville, TN
    3/8” forstner for the top
    PingGuo likes this.
  20. loopy reed
    Nov 14, 2007
    Nashville, TN
    Comme ça
    Not worried about the last hole being slightly off. It’s for the jack and isn’t going to be as noticeable as one of the knobs being off.
    PingGuo likes this.
