Tweed cabinet build
Discussion in 'Shock Brother's DIY Amps' started by dunehunter, Apr 19, 2018.
  1. stringsthings
    stringsthings TDPRI Member
    95
    Nov 23, 2016
    Indiana US
    This is an excellent thread! I've just started to build my first amp: 5F1.
    Seeing how the cab goes together is super helpful!
    dunehunter likes this.
  2. dunehunter
    dunehunter Tele-Meister Double Platinum Supporter
    464
    Jul 14, 2011
    Larkspur, CO
    Thanks! I'm taking a short break while I wait for staples and somewhat cooler weather. Just a quick note to you, I made a mistake early on with the size of the fascia boards; somewhere around page 3, I think, I started over. Enjoy!
  3. Axis29
    Jan 2, 2007
    La Quinta, CA
    Excellent work on that Bassman baffle Dunehunter!
    One thing I would suggest... instead if going straight in with the router, grab a jig saw and cut out the bulk. Leaving about 1/4" to an 1/8" makes using the router safer and much more pleasant!
    Funny how having some reference makes the whole project so much easier!
  4. Axis29
    Jan 2, 2007
    La Quinta, CA
  5. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    But if I did that, I wouldn't have any wooden frisbees to throw to my new puppy! LOL.
    Seriously, though, good idea and one I shall do in the future, along with these other router thoughts: 1) Get my router table set up--finally and 2) get a decent cordless laminate trimmer.
    BTW, just bought myself a new jigsaw too. But haven't even had it out of the case yet (except for cursory inspection, of course)
  6. Axis29
    Jan 2, 2007
    La Quinta, CA
    Shame on you! LOL
    Seriously, much of your trepidation about the router may end up being alleviated by taking smaller bites! And, if you get good with the jigsaw, you will still have frisbees, just slightly smaller ones! LOL
  7. Engraver-60
    Engraver-60 Friend of Leo's
    Jan 6, 2008
    Brentwood, TN
    I've used my speaker cutouts as templates on log halves to layout bowl blanks for woodturning.
    Axis29 and dunehunter like this.
  8. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    Must be a thousand other uses...
  9. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    So, not sure why, exactly, but I seem to be obsessing a little bit with the back panels; I only have pictures to go on and this is one case where I don't think @Axis29 can help me out with the various measurements. I know they don't have to be perfect, but I'd like to preserve as close a "feel" as possible.
  10. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    In the meantime, my staples showed up and, barring any weirdness, I should be able to post some pix of baffles before too long...
    Axis29 likes this.
  11. Axis29
    Jan 2, 2007
    La Quinta, CA
    Yeah, I had to measure existing pictures I printed out from the Internet and try to scale them appropriately... One thing to keep in mind, The guys at Fender seem to have picked nice, even or easily measured sizes (i.e. 7 1/2" or 5 1/2"). So, don't go crazy picking weird things like 5 13/64"! LOL
    They also seem to have tried to cut a lot of things the same size, and not make things too complicated. I'd wager a lot of the smaller amp back panels are the same size, top to bottom, and the same with a bunch of the bigger amps. But, that's just a guess on my part. Aren't chassis sizes kinda consistent?
  12. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    So here's the path I've been going down.
    First, like you, I've been trying to get measurements off of various pictures. I have two, maybe three "knowns": the total height of the back opening, the width of the panel, and (possibly) the distance from the top of the top panel to the tube windows (the same as the width of the chassis which I am taking as 4 1/8".
    But...
    Parallax is a problem. No one takes pictures of their amps with the idea that it will be used for measurement :(. I have been squirreling around with numbers now for a couple of days--adjusting and adjusting again, ad nauseam.
    And, as you suggested, I've also assumed that Fender used whole numbers (or at least reasonable fractional numbers like 7 1/2" or 8 1/4") rather than the weird 11/64"-type numbers.
    And, lastly, like you said, it is likely that Fender used templates to make some of this stuff and it would be practical to make a Vibrolux panel just like a Deluxe panel just like a Harvard panel, etc. Cutouts for tube coolers would be the same size and just vary by width of the panel with the slack being taken up by the far edges (center line mirror image); I would think a single template would do the trick for most of their amps (except the big ones)
    That's actually what got me started on this path--the idea of creating just a few templates and knocking these out on the router table. Can you believe it? I'm actually looking for more uses for the router now. :cool:
    Perhaps I have a fever...LOL
    Well, back to baffles, for now.
    Axis29 likes this.
  13. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    Here's a question you CAN answer for me @Axis29 ... is the height of one of the old, original Fender chassis 4 1/8"? Like the ones you can get today?
  14. Axis29
    Jan 2, 2007
    La Quinta, CA
    Yup, my Twin's is 4 1/8" tall and the vent holes are 4 1/8" from the top of the back panel as well.
    I was in a discussion with a bud of mine last night, who's had a few vintage tweeds... He was recalling that the top of the bottom panel has a bevel on it. So, now, I'll be doing some research too! Here, I thought I was done with the woodworking part of my cabinet build.
  15. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    So, just came up from the shop. I have all but one baffle done with stiffeners all in place. Here is the process:
    This is the baffle and stiffeners for one of my 5E3s. Note that the baffle screw holes are already in place.
    My first task is to test fit all the stiffener pieces again, just to make sure.
    Then, using my new silicon glue tray (a recommendation from @Axis29 --they didn't have the one I wanted but they did have this one...) and cheapo roller that I bought a while back for just this purpose, I applied glue to one side of the stiffener in a uniform fashion.
    Here's the glue spread on one of the baffle stiffeners in a nice, uniform layer; this process wastes some glue but then, so do most gluing processes in the home shop. I like the uniformity of the application.
    Next, I put the freshly glued baffle stiffener in place and tack it down with a 1/2" crown x 3/8" staple. I follow this up down it's length with staples.
    I then follow up with the right side. Glue and staples, as before, then move on to each successive side.
    I had drilled all my baffle screw holes before and now they're covered with the stiffeners. So, I drill out the holes...
    then use one of the baffle screws as a mini-rasp to open up the holes. If I'd used a waste backing board behind the holes, I would have had a cleaner final hole...
    And if you thought this process would be without hand tools, well...
    I had to trim up some extra length in the stiffeners and my block plane filled the bill perfectly.
    And here, is the final baffle, ready for...
    Oh oh...
    Axis29 likes this.
  16. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    You may have spotted my problem, but then again, maybe not. It's not entirely obvious.
    I've got the baffle board facing the wrong direction. That last picture shows how it would look from the front. It may work, but probably not--the speaker offset is on exactly the wrong side. Would it clear the power and output transformers not to mention the power tubes and rectifier? I doubt it.
    So, oops. The good news is that when I tried to take it apart to redo it correctly, I found that the glue and staples hold those stiffeners like grim death. It's essentially permanent. Nice to know it all holds together well. The other good news is that this is the only case that this happened. All the rest went just fine and came out right.
    I went ahead and put this mistake in to serve as a note of caution regarding mirror images/backs v. fronts, etc. It can go wrong with little notice until it's too late. The process is essentially a good one. Just mind your "p"s and "q"s.
    I'll put this right before the day is out and be ready for speaker screws and baffle painting tomorrow.
    Axis29 likes this.
  17. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    Had to wait to glue the replacement up; wanted to see how hardened glue in the new silicon tray cleaned up.
    Answer: Great. Now, I need to dump the old roller and get a silicone roller LOL.
    So this morning, I glued and stapled the new baffle: here it is side by side with the mistake:
    mistake on the left, corrected on the right. On to speaker screws and painting!
    Axis29 likes this.
  18. Preacher
    Preacher Friend of Leo's
    Apr 17, 2007
    Big D
    you know...
    if you made your own chassis and wired everything backward you could use that baffle mistake. Call it a left handed deluxe and you might have something valuable!!
  19. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    LOL. Thanks, I needed that!
  20. dunehunter
    464
    Jul 14, 2011
    Larkspur, CO
    But now that I think about it...
    Axis29 and Preacher like this.
