Tuner Pedal
Discussion in 'The Stomp Box' started by jkingma, Mar 1, 2019.
  1. Mike Simpson
    Gilbert, AZ (PHX)
    I The switch on my TU3 broke... not as durable as I thought. I bought a Polytune 3 because I needed a tuner that Friday night.
    Junkyard Dog likes this.
  2. GibbyTwin
    GibbyTwin Tele-Meister
    somewhere between Asbury Park and Atlantic City
    I like the Boss TU-3. New for $99, less if you find a used one. I have about 8 pedals on my board so I like that it is buffered and can also be used to power another pedal or two. Plus it is easy for me to read in low light situations. I've never had a Boss pedal fail me.
  3. john_t
    john_t Tele-Meister
    Boston
    I'll tell you what NOT to buy: Deadbeat Sound Tuner Pedal. I figured it looked kinda cool and I couldn't go wrong for $30 on Prime. I was wrong; it's completely useless. And I'm past the return period...
  4. Junkyard Dog
    Junkyard Dog Tele-Afflicted
    Me neither! And the TU is like the Telecaster of pedal tuners! I think they come with a 5-year warranty...though mine has outlived that by 10 years now.
    GibbyTwin likes this.
  5. jkingma
    N44° 59.564 W079° 35.845
    Admin Post
    I've been using a Peterson headstock tuner for years and love it for when I'm setting up a new guitar, or after I've changed strings, or when i just want to go around and tune up all my guitars. But I find it moves around a bit and has fallen off a couple time.
    I figure if I'm going to build a pedal board, I'm going to make room for a tuner. I don't have a lot of pedals anyway.
    Asmith likes this.
  6. Miguel-martinez
    Miguel-martinez TDPRI Member
    Colombia
    I own a Korg, it works pretty well.
  7. jkingma
    Admin Post
    From the responses so far it seems to be a pretty even split between the the Boss and the Polytune.
  8. imwjl
    imwjl Poster Extraordinaire
    My mom's basement.
    Seems to me that they're all more efficient than my dad's 1930's A tuning fork but I'm a big fan of the the Polytune concept of quickly showing which of all the strings is off.
    FWIW, I've used my Strobo tuner for setup, it's super detailed, but a quick tuning job with the Polytune makes most chords ring well. If I started fresh I'd use the strobe with phone app and a simple pedal for playing.
  9. Blue Bill
    Another vote for Korg Pitchblack. Works for me, easy to see in the dark, also useful as a mute switch. Plus, if you use batteries, they last a long time in this one.
    Paul in Colorado likes this.
  10. Junkyard Dog
    Probably can't go wrong with either one. A couple differences I noted...the Boss has 2 buffered outputs, so you can possibly use it split your guitar signal, run 2 amps, etc. Polytune has 3-year warranty, Boss has 5-year warranty. Looks like Polytune has a USB jack to connect to a computer, Boss does not. Polytune has something inside it that they call "BONAFIDE BUFFER"...not sure what that is, but the website may explain. I assume they both are capable of running on battery, but not sure. I frequently have gigs where amps and so forth are provided, and the only pedal I bring is my Boss TU-2 with a battery in it.
  11. KC
    KC Friend of Leo's
    Missoula, Montana
    current fave is the GoGo horizon pedal -- huge display, easy to read in any circumstance, changes color as you go in & out of tune, doesn't seem to mess with the signal on or off. It was on Massdrop for cheap -- looks like that drop is over but worth a shot if they ever come back around. I have a pitchblack, too, and no complaints.
    the thing I love about these is easy switching back and forth between guitars. I usually bring a second guitar tuned up for slide -- pop the tuner pedal into silent, switch guitars, quick tuning check and we're off to the races.
  12. Bergy
    Bergy Tele-Meister
    Denver
    I like my old TU2, but on a crowded pedalboard those Boss pedals are a little harder to access cuz you gotta push down the whole square flap of metal to turn it on. Sometimes I’ll get halfway thru kicking on a Boss pedal and realize the angle of my foot is only gonna be able to push it halfway down because of other pedals crowding it. The curvature of my pedalboard makes this worse. With polytuner it is a lot smaller footswitch, and a lot smaller pedal in general.
  13. Lawdawg
    Lawdawg Tele-Meister
    Atlanta
    One think I'll note about the Polytune is that the polyphonic tuning function (i.e. tuning all the strings at once) works well. I was dubious at first but it works great. I wish you could program alternate tunings for polyphonic tuning, but of course you can still use the Polytune as a chromatic tuner to tune each string accordingly.
  14. archetype
    archetype Fiend of Leo's Silver Supporter
    Williamsville NY
    Monoprice Chromatic Tuner pedal. $20. You can send the leftover money to me.
    Functions perfectly as a basic tuner and you can vary pitch if you want.
    Keefsdad likes this.
  15. E5RSY
    E5RSY Poster Extraordinaire
    Georgetown, TX
    I use a BOSS TU-3, but it is not on my board. I think board space is better used with an actual effect, so the TU-3 lives in the cable bag and gets put on the floor just to the right of the pedalboard when it's time to play.
    FenderLover and BorderRadio like this.
  16. bettyseldest
    bettyseldest Tele-Afflicted
    I have a Planet Waves/D'addario mini tuner on the headstock of each of the guitars I use on a regular basis, but still have a Korg Pitchblack on my board. I did have one outdoor gig where I struggled to read it in strong sunlight, but other than that one instance it is great and allows me to mute the signal when changing between standard/open G/12 String guitars.
  17. ElJay370
    ElJay370 Tele-Meister
    Los Angeles, CA
    I own the Hardwire HT-6. I think I got it new off of Amazon for around 40 bucks.
    Pros:
    Big, bright, easy to read display.
    You can set it for half step down, whole step down, and drop D.
    You can hit all the strings and tune them all at once. Good for fast in between song tuning.
    Indestructible.
    Cons:
    Kinda big. A tad larger than a typical Boss pedal. If your board is short on real estate that might be an issue. However, because it's so big it's easy to stomp on to mute.
    The die cut piece of Velcro that came with it didn't stick to the pedal very well.
  18. Paul in Colorado
    Fort Collins, CO
    I'm another Pitchblack fan. I have two of them. It's kind of hard to go wrong with any of the tuners available from the major players these days. It all depends on the features and size you want.
    Blue Bill and Junkyard Dog like this.
  19. thegeezer
    thegeezer Tele-Afflicted
    West Michigan
    Someone mentioned all tuners fail...
    My original TU-3 is a fairly early one. It’s been on my board since ‘93 or ‘94, I think. Couldn’t tell you how many gigs that is.
    Bought a second one about 10 years later expecting to need it. It’s still my “at home” tuner. Might need it someday if I live long enough.
  20. TeleFunk Man
    TeleFunk Man Tele-Afflicted
    Gatineau, Québec, CANADA
    Yep, this a great little tuner.
    Chunkocaster likes this.
