Truss rod turns..
Discussion in 'Tele Home Depot' started by tdale, Feb 7, 2013.
  1. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    I'm installing a single rod in my one piece neck. I have a hole in both ends, headstock adjust. I put a nut in the heel end, inserted the rod and started tightening the nut in the headstock end, to try how it fitted before I put in the skunk strip. Ehen the nut started tightening, the rod started turning... How do you keep the rod from turning if you're not using a barrel nut in the heel end? Will the skunk strip hold the rod in place so it won't turn, or do I need to anchor it? What should I do?
  2. kwerk
    kwerk Poster Extraordinaire
    Feb 22, 2010
    New Zealand
    Is the heel end nut turning, or is it staying stationary? If it's staying stationary, you'll need to peen the rod so the anchor nut and rod become one unit. If it's turning along with the rod, then yes, you have a problem there. I haven't ever used a single action rod, so I'll leave it up to others to suggest a solution (there will be one).
  3. tiskit86
    tiskit86 Friend of Leo's
    Jan 6, 2011
    Oakland
    I think Phil's got it right. The nut and rod on the heel end need to be one. Anchored. Married. Together forever.
    Filet strip's job is not to keep the rod from turning, but to keep the rod in the neck.
  4. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    The nut turns too, so I need to do something to keep the whole thing from turning...
  5. moody
    moody TDPRI Member
    88
    Feb 25, 2011
    colorado
    It sounds like you need a toothed anchor. Take a piece of steel rod about the size of the outside diameter of the nut, or the same size as the hole you drilled and cut off about 1/2" for a new anchor. Then drill and tap the piece to fit the trussrod where the old nut would go. Take a triangle or round file and cut two grooves at right angles to each other in one end of the anchor. This should make an anchor with four points that screws on to the trussrod. Install it on the trussrod so that the points will be toward the headstock, and then peen the threads on the other side of the anchor so the rod cannot be backed out of it. This should fix the turning problem.
  6. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    Nice tutorial! But he has a different anchor style that has no problem with turning..
  7. Bentley
    Bentley Friend of Leo's
    Jul 25, 2012
    Kelowna B.C, Canada
    Okay, I have no clue what you're really talking about. Pictures would sure help everyone.. It doesn't sound like you have a complete truss rod..
  8. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    I have a hole from the end of the neck, just like in the headstock...
  9. Bentley
    Jul 25, 2012
    Kelowna B.C, Canada
    I'm not sure why you need the hole on the back as well? What is the propose of that?
  10. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
  11. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    Just another way of ancoring the rod....
  12. Bentley
    Jul 25, 2012
    Kelowna B.C, Canada
    Okay, i'm confused, count me out, I'm past my knowledge.
  13. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    The reason is that I can use a regular hex nut, and don't have to make one... But it seems like I need to make one anyway :)
  14. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    Necks with heel adjust has a hole in both ends... this is just the same basically, only I chose to adjust from the headstock..
  15. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    I'll try Moody's tecnique, thank you!
  16. Bentley
    Jul 25, 2012
    Kelowna B.C, Canada
    Okay, I think I see what you mean.. Where is the nut that you have the truss rod threaded in to located?
  17. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    At the end of the rod, in the heel end. The adjusting nut is in the other end
  18. tiskit86
    Jan 6, 2011
    Oakland
    So there's a channel all the way from the headstock through the heel? A hole on each end?
    If that's the case I think you should plug the hole at the heel and anchor the rod an inch or so short of the end of the heel. Like this, yes?
  19. tdale
    tdale Tele-Meister
    292
    Aug 29, 2008
    Norway
    That is a way, yes... I wanted to avoid having to make a nut... But I might do it this way after all, or make a nut like moody explained
