Join TDPRI Today
Tru-Oil?
Discussion in 'Finely Finished' started by Guinness, Mar 26, 2010.
  1. Guinness
    Guinness Tele-Meister
    257
    Jul 13, 2008
    Dover, DE
    Finally got to the point where I simply couldn’t stand the sticky lacquered neck on my 52ri Tele & 58ri Les Paul.
    So, I got one of those green scrub pads and lightly rubbed down the back of each neck. This got the stickiness off with very little effort. A HUGE improvement in feel. I’m quite happy with them both.
    Now I’m wondering if I’ll need to use Tru-Oil on the necks to protect them & keep from warping. What do y’all think?
    I read an older post http://www.tdpri.com/forum/finely-finished/202868-untreater-neck-help.html that really praised the feel of a neck treated with Tru-Oil.
    How does this treatment make the neck feel?
    Would using it over a stock satin finished neck be an improvement?
    Thanks!
    ~Randy
  2. JCBurke59
    JCBurke59 Tele-Holic
    878
    Jan 7, 2009
    Long Island, NY
    I wouldn't worry about it. If you like how it feels now, I'd just leave it as is. There have been a few threads lately on the subject of 'unfinished' necks and the consensus seems to be that warping and other problems are rare. The common wisdom is that lacquer can be okay on top of other finishes, but other finishes on top of lacquer generally don't work out.
    As to Tru-Oil in general - I really like the feel and it's about all I will use these days on my builds. And I recommend it on a regular basis to others. But the difference for me is that I'm always starting out with a fresh unfinished neck. I start to worry about compatability problems when 'mixing' or layering finishes.
    Once you've got it feeling good, it's a good time to stop working on it.
  3. WrayGun
    WrayGun Tele-Afflicted
    May 5, 2006
    Pittsburgh, PA
    Don't take my word for it, but I've read somewhere (here) that you can lacquer over a Tru-Oil finish, but not vice-versa.
  5. JCBurke59
    878
    Jan 7, 2009
    Long Island, NY
    That's true. All of the Tru-Oiled necks I've done have lacquer (nitro) sprayed over the Tru-Oil on the headstock faces. No problem there.
    In my opinion it doesn't make sense to lacquer over Tru-Oil on any part of the neck that makes contact with your hand. The main advantages of Tru-Oil are ease of application, durability and 'feel'. And the 'feel' part is really, really good. The main objection for most who don't like lacquer on their necks is that the lacquer feels sticky. I spray lacquer on the headstock to 'bury' decals. It will also check (Tru-Oil does not) so if you're after a 'vintage' look, that's one way to get it.
  6. mudbean
    mudbean Friend of Leo's
    Hey Randy - You only rubbed the necks with a green scrubby pad? I'd be quite surprised if you took the whole finish off, down to bare wood. So, I'm thinking that you don't need to add any finish for the purpose of protecting the wood, because there's still plenty of goop on there.
    mud
  7. Guinness
    257
    Jul 13, 2008
    Dover, DE
    Thanks guys!
    Yeah, I just used a green pad, didn't rub hard- just enough to get the stickiness off & for the necks to have a satin like feel. I did see some residue similar to dust in the bad when I finished, but attribute that to the lacquer.
    I've been considering using some Micro-Mesh to restore the glossy look, but might just leave it as is.
    Thanks again!
    ~Randy
  8. flyingbanana
    flyingbanana Poster Extraordinaire
    Some fast rubbing with Mother's Metal Polish will shine that right up if you have any finish left on it. Don't laugh...I know it's a metal polish, but it really works great. You are only using it as a polish, and hence, most of it simply absorbs back into the applicator towel.
    This stuff is fantastic...and it won't make the neck sticky.
