Join TDPRI Today
Tips on lining up bridge with neck?
Discussion in 'Tele Home Depot' started by skycricket, Nov 5, 2012.
  1. skycricket
    skycricket TDPRI Member
    10
    Oct 22, 2012
    I'm about to bolt on the neck and I was wondering what's THE best way to make sure that sucker is lined up with the neck to avoid strings hanging off of neck??
    **picture of nice vintage acoustic I found, just to draw more eyes to the post ;-)
  2. nadzab
    nadzab Friend of Leo's
    Mar 23, 2009
    New England
    Assuming nothing was botched in the earlier phases of construction (and you've already drilled the holes in the pocket and the neck), this is an adjustment that I fine-tune after the guitar is strung up. Loosen the mounting bolts slightly, and you can bring the neck a bit left or right until the alignment is where you want it, then re-tighten.
  3. Rich Rice
    Rich Rice Poster Extraordinaire
    Jul 15, 2005
    Chicago 'Burbs
    If you clamp the neck to your exact position, you can hold two straightedges (I like metal yardsticks for this) against each side of the neck. At your point of intonation, stick some masking tape to the face of the body and draw (lightly) two pencil lines to give you both edges of the neck (extended). Split the distance between those lines at the bridge location, and you have established your center line. Armed with a center line, two outer lines, and an intonation line, you have many points of reference with which you can locate your bridge.
  5. u-design-it
    u-design-it Banned
    467
    Jul 19, 2011
    Belgium
    you can use a laser
    works fine fore me
  6. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    From a thread I did a while back on how to install threaded inserts. This applies to your question. If you don't want to use threaded inserts. Just drill the pilot holes in the neck at 1/8".
  7. kwerk
    kwerk Poster Extraordinaire
    Feb 22, 2010
    New Zealand
    +1
    Best method I've found. Unless you do have a laser. :D
  8. braderrick
    braderrick Tele-Afflicted
    Sep 27, 2006
    Kentucky
    If the bridge and nut are already installed, I just use a clamp like posted above and run one long piece of thread through one of the E string ferrules, through the nut, from that E tuner hole through the other E tuner hole, back down through THAT nut slot and down through the opposite E ferrule.
    You can tighten the thread and tie the ends together if you want at the string ferrules. Then move the neck back and forth until you are happy with the string path and lock the clamp in place. I then use a drill bit to mark the neck for drilling.
