Join TDPRI Today
Three bundles of joy!
Discussion in 'Tele Home Depot' started by Mark Adkins, Apr 24, 2013.
  1. Mark Adkins
    Mark Adkins Tele-Meister
    251
    Feb 17, 2013
    Petoskey, MI
    These are my first three builds ever. I must first say thank you to all the exceptional builders in this forum. The knowledge and insight you all provide really helps a newbie get started.
    After doing a ton of research, I started buying tools and materials in December of last year. I was able to finally start in January of this year. The first two bodies are one-piece swamp ash, and will have SD Lil 59s in the Bridge, a standard Tele bridge PUP in the mid position, and a standard Tele neck PUP in the neck position. The third one will have a TV jones HB in the bridge position, standard Tele bridge PUP in the mid position, and a standard Tele neck PUP in the neck position. It will also have a Ghost Tech piezo system as well.
    I haven't built a router sled yet, so I have one side jointed at a wood working shop and then level the other side in my planer, as well as reduce it to the proper thickness. Here are some pics of all three builds so far. Once it stops snowing and warms up here (northern Michigan) I'll be able to spray some color and clear coat on them.
  2. guitarbuilder
    guitarbuilder Doctor of Teleocity
    Mar 30, 2003
    Looks good. If you don't have a planer, then a router planer jig will help you get by, but it if you do have a planer, you don't need to fabricate one. I'd put that effort into other other jigs for making necks. Unless you have horribly twisted wood, you can carefully alternate plane both sides of rough wood up to the width that your planer will take, at least for bodies and necks.
  3. Ronkirn
    Ronkirn Poster Extraordinaire Vendor Member
    Jacksonville, FL
    c'mon.. you can squeeze a few more knobs 'n switches in there... where's your sense of adventure..? ;)
    Oh.. that TonePro bridge is a really nice piece...
    rk
  5. Mark Adkins
    251
    Feb 17, 2013
    Petoskey, MI
    I'll give it a shot on my next blank. I don't have any twisting, just some cupping. I thought my planer would push it flat and let the cup reappear after it comes back out.
  6. Mark Adkins
    251
    Feb 17, 2013
    Petoskey, MI
    Lol! I was thinking of naming it the millennium faulkencaster. I like both bridges I've ordered so far. I'll probably stick with the Schaller when possible, but the Hipshot works better with the Ghost Tech saddles.
  7. Mark Adkins
    251
    Feb 17, 2013
    Petoskey, MI
    Also, I love your avatar!! I just moved to north Michigan in March of last year. Before that, I was a Jacksonville, FL native for 12 years. Before that I was born and raised in West "By God" Virginia (that's how we are taught to say it there):p
    My home office (CSX) is still in Jax so I'm there 4 weeks out of the year. I'll have to stop by and say hi next time I'm in town.
  8. guitarbuilder
    Mar 30, 2003
    Start out with the cup down so the planer takes off some from the middle or the high point of the wood, then flip it and run it in so the knives are cutting the edges, them flip it again, and so on. Eventally both sides are flat and parallel. Take small bites each time....This is exactly how I plane my one piece blanks.
  9. TRexF16
    TRexF16 Friend of Leo's
    Apr 4, 2011
    Tucson
    I like the way you have fearlessly taken on some fairly challenging builds for your first(s). These are going to be very cool and I have no doubt you'll do great on them. What do you have planned for the necks?
    Rex
  10. Mark Adkins
    251
    Feb 17, 2013
    Petoskey, MI
    Cool! I'll do that with my next blank. Thanks for the tip!!
  11. Mark Adkins
    251
    Feb 17, 2013
    Petoskey, MI
    I wouldn't say fearless. I did spend A LOT of time learning how to do what I want to accomplish, which includes a lot of reading the tips and tricks from the builders in this forum.
    For now I have ordered three necks from Warmoth. I plan to buy the rest of the tools I need this year so I can build my own.
  12. Mark Adkins
    251
    Feb 17, 2013
    Petoskey, MI
    Lesson learned! I'll admit it... Since birth I have been a "learn the hard way" individual. Life experience has helped reduce the hard way lessons, but they still occur from time to time.
    I was so eager to complete a build, that I decided not to do a practice build on some cheap lumber, which would've let me learn from any mistakes I was making. Instead, I went head first into three nice pieces of swamp ash. Not to sound cocky, but I think I did really well. I made a few errors, but with the help of all the great info in this forum I was able to correct them. The big error, while correctable, will take a bit of work and the acquisition of some wood.
    I was trying a new set-up, in which I would place a humbucker in the bridge position, and move the standard Tele single coil bridge pup to the mid position. The mistake I made was not understanding the difference in string spacing between the two positions. While 17/73/107 degrees (depending on how you look at the protractor) works in the bridge position, it does not let the pole pieces line up with the strings in the mid position. Instead, it has to be at 28/62/118 degrees.
    I have set these three bodies aside for now, and plan to fill the mid pickup rout, and re-rout it at the correct angle, after I glue on a nice maple top.
    The good news is, I was at the point of color and clear coat, so this issue won't happen again. I know now to make a template and verify all angles and measurements before working with the good wood.
    Luckily, I had more blanks in the shop, and I have three new bodies ready to go. I'll use those for now, and repair the first three at a later time.
  13. Flynztone
    Flynztone Tele-Holic
    803
    Nov 28, 2011
    Flint, Michigan
    Where are you at in Northern Michigan? That's a far cry from Jacksonville FL and there's not a more beautiful place on the planet than Northern Michigan in the summertime but the winters can get pretty brutal. Heck, I am down in Flint MI and I have the heat on today it's bleeping cold man
  14. Mark Adkins
    251
    Feb 17, 2013
    Petoskey, MI
    I am about three hours north of you in Petoskey, MI. It's on Lake Michigan in Little Traverse Bay. It's about 40 minutes south of the Mackinac Bridge.
    It is cold here too! The week before Mother's Day weekend it was up in the 80's and I thought I was finally going to be able to paint. But then it snowed that weekend, and has been raining a lot since then. Good thing, as I hadn't discovered the improper angle for the mid pickup. Had I painted them, I would have had to remove the finish to make the corrections.
  15. Flynztone
    803
    Nov 28, 2011
    Flint, Michigan
    I know right where you're at been there many times. Petoskey MI is beautiful and former Flint native and Grand Funk Railroad bandleader "Mark Farner" lives up there too.
  16. Flynztone
    803
    Nov 28, 2011
    Flint, Michigan
    Hey Mark Adkins,
    Have you found any good sources for rough sawn hardwood up your way? I know there's lumber mills all over the place up there so was just wondering if you've had any luck? I get up that way quite often throughout the summer months actually so if you know a place I would be interested in checking it out. There's a great source for rough sawn cedar in Boyne City but I don't know how that would work out in guitar building. I have some Spanish cedar here to build a classical but ht was purchased through a luthier supply house.
  17. Mark Adkins
    251
    Feb 17, 2013
    Petoskey, MI
    I haven't really had a chance to check out the local mills, but from what I've seen and heard, they mostly focus on construction timber and sheeting. There is a place I heard about in Traverse City called Rare Earth Hardwoods that I've been meaning to check out. They deal with local domestic as well as exotic woods, and even cater a little to the luthiers with some tone wood.
  18. Mark Adkins
    251
    Feb 17, 2013
    Petoskey, MI
    I've met him. He is good friends with my Wife's family (Pastorius family - related to Jaco Pastorius). He even helped my father-in-law build the deck on his house.
    I fell in love with this place the first time I vacationed here. Jacksonville, FL was a big adjustment for a WV country boy, but I grew to love it there. But the last few years the crime has just exploded there. And don't get me started on the traffic! Then I met my wife and that really cemented my decision to relocate. Michigan is part of my territory for my day job, so my boss was kind enough to let me set-up a home office and work from here. I still have to spend a week every quarter at HQ in Jax. Now instead of sitting in traffic for an hour each way, I just walk down the hall and log in. I love it!!
  19. Flynztone
    803
    Nov 28, 2011
    Flint, Michigan
    Yeah Mark is good people as is the rest of the Farner family. I am real good friends with his brother Ricky and ironically he's now living down in Florida. There will never be another innovator like Jaco ever. He was from another planet I think.
    I am a network admin by profession and work from home 80% of the time and remote into all my client locations. Occasionally I have to go onsite but I work from home most the time and have been for years.
  20. Flynztone
    803
    Nov 28, 2011
    Flint, Michigan
    I will have to check that out do you know the name of the place? I have a few gigs up in TC this summer as well as a couple in the fall. I know a lot of musicans up there and believe it or not, Traverse City has some damn good musicians in that town. Of course Interlochen school of performing arts is right there so I guess it stands to reason but there are some great players up there
  21. Flynztone
    803
    Nov 28, 2011
    Flint, Michigan
    Rare Earth Hardwoods sorry my bad
