Third unwound string rattles
Discussion in 'Bad Dog Cafe' started by 8barlouie, Mar 19, 2019.
  1. 8barlouie
    8barlouie Friend of Leo's Gold Supporter
    Seekonk, MA
    I have a Tele whose third string rattles like a broken kazoo no matter how or where I play it including open. Funny thing is, my DRRI and my THR10C is deaf to it. It only happens when the guitar is unplugged. I guess it shouldn’t bother me, but I’m gonna drive myself crazy not knowing what is causing it. Any ideas?
  2. unixfish
    unixfish Poster Extraordinaire
    Northeast Ohio, USA
    What bridge is on the Tele?
    My guess is it is something on the bridge rattling - if you have individual saddles, I would check that.
    I assume the third rattles regardless of what fret you are playing - right?
    8barlouie likes this.
  3. esseff
    esseff Tele-Holic
    East Midlands, UK
    Have you got strap locks fitted without the straps? That was the cause of one of my guitars giving the same problem. Sympathetic resonations were causing the rattling. Took ages to trace it.
  4. 8barlouie
    Seekonk, MA
    I have a Rutters three barrel Vintage style bridge with brass saddles. Yes, it does happen all along the fretboard. I’ve even tried tapping on each end of the barre with a rubber mallet.
  5. 8barlouie
    Seekonk, MA
    Aaah, so! I hadn’t considered that possibility. Thanks I’ll check into that.
  6. dickey
    dickey Tele-Afflicted
    If it doesn't happen when the guitar is plugged in, why worry about it?
  7. Toto'sDad
    Toto'sDad Telefied Ad Free Member
    Bakersfield
    Just because!
    Torren61 and 8barlouie like this.
  8. fraser
    fraser Tele-Holic
    Hamilton, Canada
    I too would first look to the saddle.
    But if that is a dead end,
    Do you have 2 string trees on this guitar?
    If only one, try pressing down slightly on the ringing string, ( you are talking of the G yes?)
    Behind the nut.
    What can happen is if the string is wrapped in a way at the tuner that gives too shallow a break angle,
    The string rattles off the sides of the back of the nut slot.
    Normally it occurs as an unpleasant ringing along the string,
    More obvious with hard, open picking,
    But can be heard while fretting as well.
    Hard to explain in words,
    But if applying down pressure on the string behind the nut cures the problem,
    Simply restring, and give the string a good 4 wraps around the tuner post.
  9. ecoast
    ecoast Tele-Holic
    NWNJ
    maybe nut
    magicfingers99 likes this.
  10. magicfingers99
    magicfingers99 Tele-Afflicted
    atlanta
    if the nut slot is too wide it might be vibrating in the slot rather than being taut and vibrating after the nut.
  11. magicfingers99
    atlanta
    could also be a loose truss rod cover..
    Torren61 likes this.
  12. cincyguitarplay
    cincyguitarplay Tele-Meister
    ohio
    I had the open G string rattle like crazy on my LP...I think the nut was causing it....I tried a heavier gauge string and that stopped it...
    8barlouie and Torren61 like this.
