There was a word heard round the block.
Discussion in 'Tele Home Depot' started by Ja S, Feb 3, 2013.
  1. Ja S
    Ja S TDPRI Member
    59
    Aug 31, 2012
    Chicago
    looks like my two piece becomes a three piece.
  2. Jupiter
    Jupiter Doctor of Teleocity Ad Free Member
    Jun 22, 2010
    Osaka, Japan
    That'll buff out.
  3. fluid69
    fluid69 Tele-Holic
    755
    May 13, 2010
    usa
    Ouch! Im betting the "word" heard around the block would violate my virgin ears. You got the right idea though, patch it in. Everything else looks nice and clean and the way the grain is running should blend in.
    "If you want rules, read the IRS tax code. If you want to build guitars, make some sawdust." -Colt W. Knight
  4. RogerC
    RogerC Poster Extraordinaire Vendor Member
    Mar 30, 2011
    Oklamerica
    That sucks. I would rout it nice and square and glue in a block, being careful to match the grain. It's a setback, but definitely not project-ending.
  5. LeftyAl
    LeftyAl Friend of Leo's
    Mar 24, 2010
    Fl.
    Yeah, I think you put in a piece of wood there,match it up the best you can.I think the pickguard will cover it up
  6. garytelecastor
    garytelecastor Poster Extraordinaire
    So it was you.
    We had a bet going that it was somebody here in the tundra.
  7. Ja S
    Ja S TDPRI Member
    59
    Aug 31, 2012
    Chicago
    Ya that's the plan route large glue it in and re route. Sometimes it would be better to not go for that last cut of the day.
  8. Barncaster
    Barncaster Poster Extraordinaire
    Just one word? You have amazing control. Time for a nice thin 2 piece SA cap to be hidden by binding. It's funny how projects sometimes change direction on you. Don't worry, what ever you end up with will be excellent!
    Rob
  9. mgaut051
    mgaut051 TDPRI Member
    81
    Apr 21, 2010
    Calgary
    Or zebrawood. Or wenge. Or rosewood. Or curly walnut. Or spruce. Or anything really.
  10. Jupiter
    Jun 22, 2010
    Osaka, Japan
    Or paint!
  11. Jfellows
    Jfellows Tele-Afflicted
    Aug 23, 2012
    Tracy, California
    The last time I did something like that my wife came running out into the shop expecting to find me with only 6 fingers left or something.
    Just keep it in perspective. You could've knocked it off the bench onto the concrete floor, cracking off a huge chunk during final buffing. But I don't know anyone that has happened to.... ;)
  12. guitarbuilder
    guitarbuilder Doctor of Teleocity Ad Free Member
    Mar 30, 2003
    Set up a fence and stop on top of the body and run the router into the gouge. Then take scrap from that end of the cutoff and carefully select the portion so the grain is running in the identical direction and facing the same way as the rings of the body. Other than a glue line, with a sharp bit, you should be OK. Make it fit well, not too tight, not too loose,and don't use a ton of glue. This kind of stuff happens to everybody once in a while.
    If it were me, I'd rout a straight line into the pickup and fill it with matching wood. That way you don't have to fool with sanding a curve in the end of the plug where the glue line would show the most. Been there and done that.
  13. newtwanger
    newtwanger Blackguardian. Ad Free + Supporter
    Feb 11, 2007
    Quebec, Canada
    Route large and you will see the fix. chisel square and close, and it stays under the pickguard.
    Unless it's a solid finish, then it's all fun and candy.
  14. guitar2005
    guitar2005 Tele-Holic
    710
    Oct 22, 2010
    Canada, Québec
    That has happened to me three times, not as bad but ite the same issue regardless - you have to fix it.
    Don't get discouraged, it happens to the best too.
  15. Waylanderer
    Waylanderer TDPRI Member
    74
    Aug 14, 2011
    Buffalo, NY
    I've made exactly that mistake too. Took a (long) breather, patched it.
    People have suggested caps, solid color, pickguard etc, but I don't think that anybody has suggested a burst, which might be enough to obscure any patch (if you aren't liking any of the other ideas). Although it'd have to be a pretty thick burst, so that may not work. Well, you've got plenty of suggestions. Good luck!
  16. Rich Rice
    Rich Rice Poster Extraordinaire
    Jul 15, 2005
    Chicago 'Burbs
    Yeah, it's a pisser- but certainly not a big problem. Looks worse than it is. If it were me, I'd rethickness from the top, rout a couple of lungs, apply a nice face, bind the top, and be even happier with the final body. Or let the painter fix it.. LOL
  17. LowNote
    LowNote Tele-Meister
    112
    Nov 8, 2012
    Moreno Valley, CA.
    Hey, what was that about a painter? I'm a painter and I resemble that remark.:lol:
    Anyway about the neck pocket. If it were me I would reattach the neck jig but move it over to furthest edge of the rout and down the middle of the grain. The jig will be angled but, following the grain. It looks like the edge of the rout stops at the grain. Rout all the way to the top removing all the wood. That way when you glue the new piece in the only line will be in the dark grain and at the lower left corner of the pocket. No glue lines going across the grain. Does it make since? Just my .02 cents.
    LowNote
  18. thumbpick
    thumbpick Tele-Afflicted
    Nov 22, 2012
    somewhereville
  19. SixShooter
    SixShooter Friend of Leo's
    Sep 20, 2008
    Cincinnati
    Please post pictures of the fix. Most of us run into some kind of setback or another. As builders we need to learn how to recover.
  20. flatfive
    flatfive Friend of Leo's
    Apr 23, 2009
    Monterey, CA
    +1 No problem. I recently had to do this after stupidly
    routing a neck pocket with the template backwards,
    so that the wide end of the pocket was towards the
    neck.
