The truth about olive oil for our telecaster
Discussion in 'Telecaster Discussion Forum' started by Moniyaw, May 23, 2019.
  1. Deeve
    Deeve Friend of Leo's Silver Supporter
    Ballard
    Olive oil - Mrs Deeve uses it for roasted beets, carrots, spuds, etc.
    Or Salad dressing.
    Not used for even a roasted neck.
    Peace - Deeve
    Obsessed and Nightclub Dwight like this.
  2. Cheap guitar guy
    Cheap guitar guy Tele-Meister
    PA
    The F-one lasts for a year if the board is cleaned correctly and the conditioner is applied correctly. An unfinished board is not supposed to feel greasy. It is supposed to feel smooth. The idea is to keep the natural oils in the rosewood preserved. I did this with a 30 year old
    acoustic. Clean the fretboard with non ammonia window cleaner until the rag shows no more dirt. Then using 600 grit sandpaper polish the frets and your fretboard with it. Be gentle but hit the whole board with the paper. Clean it again with window cleaner and let it dry. Put a small dot of f-one on every fret and rub it in and let it sit for a few minutes. Then wipe it off with a dry clean cloth. Repeat this process until the board stops absorbing. Wipe it off completely. Your board will be perfect. And this product will not loosen your frets.
  3. jrblue
    jrblue Tele-Afflicted
    Santa Barbara
    Bore oil is best, olive oil is bad. You may get away with it, but it's foul.
    FrontPU likes this.
  4. schmee
    schmee Poster Extraordinaire
    I dont think Olive oil will rot the wood, but no I would generally avoid using food type oil. They like to grow things and do go rancid after a while.. However, not a huge deal either if the oil you use is fresh.!
  5. DFB1
    DFB1 Tele-Meister
    Denver
    I just wipe the board down with thick cut bacon.
    ozzeng, Tele295, Wildcard_35 and 13 others like this.
  6. Cheap guitar guy
    PA
    I'm telling you bro you do this and you will be very happy with the results. I am not a luthier but I did stay at a Holiday Inn last night.
  7. TeleTown
    TeleTown Friend of Leo's
    Twangers Medows USA
    I use Guitar Honey twice a yr. Hell, im in Ariz. and I aint got no problems as long as my humidifier is running.
  8. warrent
    warrent Friend of Leo's
    toronto
    You've all got me worried now. The fretboard below is 60 years old and was last oiled sometime in the 70's. Is it going to go bad now? If I use olive oil should it be extra virgin? Single estate? Will the tone vary if I use Italian or Californian olive oil?
  9. simond
    simond Tele-Meister
    Tasmania
    I have had a little bottle of Huon Pine oil for conditioning fret boards for thirty years or so. Huon logs that were cut 200 years ago and left in the water are still fished out and yeild good timber because of the oil content. Best boat building timber in the world. Smells wonderful. You might find it hard to get if you're not in Tasmania.
  10. memorex
    memorex Friend of Leo's
    Chicago
    If you use Olive Oyl, Popeye may get angry. Look out if he eats his spinach.
  11. Moniyaw
    Moniyaw TDPRI Member
    Wetaskiwin, Alberta
    As an Italian guy, I'd say Italian.
    But really, it hasn't been conditioned for almost 40 years? How does it look so good?
  12. Chunkocaster
    Chunkocaster Friend of Leo's
    In space with Ziggy
    Olive oil feels tacky for a while when I have oiled a wooden cutting board with it.
    I use lemon oil, my nicest looking rosewood neck has a coat of tru oil on it and has not needed recoating since applying it. I had ebonized it and it failed starting to come off over a years use so I had to re ebonize it then seal it with tru oil. I wouldn't do that with a normal rosewood neck though unless you had to seal it for some reason.
    Baby oil may work well? It's cheap too or you could just get it for free by rubbing your neck on a stripper.
    Kriticaster and Lake Placid Blue like this.
  13. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    Look, it's not crazy rocket science. Woods that you don't want to dry out, and are unpainted, need a little bit of oil once in a while. I have unfinished butcher block counters in my kitchen (maple fwiw) and about once a month they need a wipedown with mineral oil. Most every product out there to condition fretboards is mineral oil + a few little odds and ends which are not needed. Guitar Honey, yadda yadda, whatever - it's mineral oil + some silliness. Rosewood is an exceptionally oily and hard wood that needs a lot less care than a butcher block. It most definitely does not need a monthly application of anything, and definitely not olive / peanut / corn oil. Get a bottle of mineral oil from Home depot for about $5, apply it once a year, and you'll be just fine.
  14. Wobbles
    Wobbles Tele-Meister
    Snowlake Arizona
    I've used baby oil for decades. Can't even remember who told me to use it. Seems to work just fine.
    Chunkocaster likes this.
  15. lightningflash
    lightningflash Tele-Meister
    Yep, mineral oil.
  16. Chunkocaster
    In space with Ziggy
    Do you buy it or rub your necks on strippers?
  17. toomuchfun
    toomuchfun Tele-Holic
    NE US
    Tell the truth, is it Rachael Rays favorite, EVO?
    It's your guitar, you can do what you want. Just don't call it an upgrade if you ever sell it.
    There was a time when Martin recommended 3 in 1 oil for rosewood fingerboards.
    NothingGoatboat likes this.
  18. Chunkocaster
    In space with Ziggy
    Thinner oils work better than thicker oils and tend to feel less sticky.
    It's nice to have a scented oil too which is why lemon oil is so popular.
    It's also cheap and a bottle lasts a decade or more.
    Or you could just get a maple neck and not need to do anything to it to make it look good.:)
    BuckSatan and Lake Placid Blue like this.
  19. asnarski
    asnarski TDPRI Member
    grand rapids
    FDA food grade butcher block oil. Found a small glass bottle of it in a little general store in Tenn. Clear no smell, never sticky and oily. Feeds wood with little or no darkening and lasts me about 2 yrs. Love it cuz of no oder etc.
  20. Moniyaw
    Wetaskiwin, Alberta
    I'll try baby oil next time.
    Maybe I can rub my guitar neck on a stripper lol
    Kriticaster likes this.
