The Couchcaster
Discussion in 'Tele Home Depot' started by Rjelecaster, Nov 11, 2018.
  1. Rjelecaster
    Rjelecaster Tele-Meister
    Europe
    Im starting my next build. Have started doing the mdf templates for the necks and bodies.
    I was all set on doing a normal tele from the swamp ash body blank I have. Im now thinking about doing a jazzcaster instead:
    To make it a true couchcaster, I would move the input jack to the control plate and use a toggle switch on the lower bout to select pickups.
    Any comments?
  2. Mat UK
    Mat UK Tele-Afflicted Silver Supporter
    London, UK
    Only that it sounds like a good idea. I like an offset shape.
    2blue2 and Rjelecaster like this.
  3. matmosphere
    matmosphere Tele-Meister
    District of Columbia
    I love my jazzmaster but my tele is way more comfortable to play in a couch.
    The big offset lower bout make the jazzmaster a little awkward
  4. Bangdapoontwang
    Bangdapoontwang Tele-Meister
    Hawaii
    Maybe short scale like a Jag? That seems like it would be more comfy on the couch.
    Deegatron, Rjelecaster and 2blue2 like this.
  5. guitarbuilder
    buckobell and Rjelecaster like this.
  6. Old Tele man
    Old Tele man Friend of Leo's
    Tucson, AZ
    KISS, use the 'simple' Duo-Sonic pickup toggle selecting circuit!
  7. Rjelecaster
    Europe
    well this escalated quickly, already plotted and glued on to mdf
    I basically loaded a few pictures of jazzcasters and the Tdowns tele drawing as external references in autocad and started drafting. My most favorite shape did not have sufficient space available for a tele control plate, while others that did had to much going on behind the bridge. So I switched things around until I had something I thought looked ok and would fit my two piece my body blank.
    Ekko likes this.
  8. Rjelecaster
    Europe
    Im not sure how much the lower bout resembles a ture jazzmaster, Ill keep this in mind once I have sawn out the template.
    Good suggestion, but in the true spirit of Leo, I'm keeping things modular, and thus 25.5 in ;)
    ah... 2009, when these things were still original!
    simple is my middle name, no wait, its my nick name!
    guitarbuilder likes this.
  9. TRexF16
    TRexF16 Friend of Leo's
    Tucson
    Look at your diagram and this will make a lot of sense, based on where the lower curve wants to sit on your leg. Looks like it's too late now so hope the shape you have chosen works out great. The idea of a couchcaster is a good one, as it seems I spend a lot of time playing there myself.
    Rjelecaster likes this.
  10. Rjelecaster
    Europe
    The point of no return has yet not been reached. I have merely glued the drawing on the mdf plate, the body blank can still either become a tele or a telemaster.
    I basically started off doing this because I had read repeatedly about Jazzmasters having been designed for being played while sitting and were supposedly wery comfortable that way.
    Here is a comparison between a tele (black), Jazzmaster (blue) and the shape I have been working on (red).
    I have been changing the front a bit, so I think I will have to print it out again and glue over the plotted drawing.
    Ekko likes this.
  11. 10orgtr
    10orgtr Tele-Meister
    western PA
    I'm really liking the red shape. Just a thought though, perhaps move the Tele control plate maybe 3/8" toward the bridge, it looks a little close to the edge as is.
    Cheers,
    Woody
    bcorig and Rjelecaster like this.
  12. Deegatron
    Deegatron Tele-Meister
    Alberta, Canada
    I second this. built my couch caster with a 24-5/8" scale and it's not quite short enough. LOVE that guitar to death but a true couchcaster needs a nice short scale on her...
    Danjabellza and Rjelecaster like this.
  13. Rjelecaster
    Europe
    Ok, point taken gentlemen.
    I have three necks to make. One of them will be a 24 inch conversion neck. It will be fun to figure that out.
    bcorig likes this.
  14. 10orgtr
    western PA
    That shouldn't be too bad to do. You know where the bridge has to be in relation to the neck pocket for the regular scale neck to work. Just work backward off the bridge to locate the nut and you have your neck length. And if memory serves me right, a 24" scale's fret layout is the same as the 25.5" scale with the first fret cut off.
    Cheers,
    Woody
  15. Rjelecaster
    Europe
    Just what I had in mind.
    I also modified the contours still and shifted the control cavity a wee bit. Now the distance to the edge of the body is the same as for the tele.
    And all by itself:
    Shuster, bcorig and Ekko like this.
  16. Macrogats
    Macrogats Tele-Afflicted
    Auckland, New Zealand
    That's interesting to know. I'm planning a 24 inch scale build sometime in the future, so this would be very handy.
  17. Macrogats
    I'm also liking the look of this design. Can't wait to see how this comes together.
  18. brogh
    brogh Assistant Admin Staff Member
    italy
    Admin Post
    It looks very similar to the meteora :) i'm liking your take, it's slightly different an lees " pointier ", lower arm pocket is way better on yours:)
    Rjelecaster and Ekko like this.
  19. Rjelecaster
    Europe
    This is what it would look like with a 24 inch conversion neck:
    Where should I place the bridge axis in relation to the saddles?
    Ekko likes this.
  20. brogh
    italy
    Admin Post
    uhm, just a note...
    i think you might need to recess the cavity a little bit, like half inch, just to play it safer, looks close to the bridge, the switch might get hit during yeah well.. Rock N Roll !!! :lol: i know it's probably in the same place as a telly, I've heard some people complain about it, I reversed the plate :p, it might give it a more willowy look
    does it come in sunburst with a maple neck and black pickguard steel medium jumbos and a 4 way switching ? :D and how would it look with a full 25.5 ?
    when can i place an order ? ;)
    cheerios
    Ekko and Rjelecaster like this.
