The Build Commences...
Discussion in 'Shock Brother's DIY Amps' started by shortcircuit, Jun 14, 2018.
  1. shortcircuit
    shortcircuit Tele-Meister
    North Carolina
    There's a 5Y3 and a 6V6GT, single-ended. A cathode follower will be driving a tone stack ripped off from the AB763. Feel free to speculate as to the rest of the build.
    kleydejong, CoyotesGator and dan40 like this.
  2. shortcircuit
    North Carolina
    Filaments wired up. The wire is 20 AWG nickel plated fluoropolymer insulated twisted pair, supposedly specced for the ISS....yea.
  3. shortcircuit
    North Carolina
    The window for the indicator light is a 3/8" hole filled with epoxy mixed with small bits of aluminum (from drilling the holes) and graphite powder (scraped from pencil lead). You can see the blue painter's tape through the lower bolt hole.
    The indicator light runs off the 6.3V filament tap, full wave rectification with 1N914's and a capacitor so that when I turn off the amp, the LED fades out like an incandescent bulb. This is a true sign of a diseased mind.
    jtcnj, CoyotesGator, robrob and 2 others like this.
  4. shortcircuit
    North Carolina
    My standard power supply built on a cut down piece of a turret board. The 2 47uF caps are Panasonic's. All three are rated for 105 degrees C and 10,000 hours. Can't get that in axial caps. The single turret is for the voltage divider for the elevated filament supply because of the cathode follower.
    CoyotesGator, robrob and 2blue2 like this.
  5. shortcircuit
    North Carolina
    From left to right: 1st preamp tube, 2nd preamp tube (I also have a glass version), 6V6GT, 5Y3.
    Nickfl and Jake Nelson like this.
  6. shortcircuit
    North Carolina
    The preamp...she is done. In case if anyone is wondering, the film caps are not generic brown boogers. They are Matsushita/Panasonic polyester caps (but still dirt cheap). See the "M" logo below.
    Inglese, CoyotesGator and robrob like this.
  7. bigguy12321
    bigguy12321 Tele-Meister
    Traverse City Mi.
    Now I know why the dogs are dancing in the morning to go outside. EXCITED. EXCITED, EXCITED!!!
    Beautiful work Shortcir! I don't have any idea what it will be but I can't wait.
    Do you have any pics of the underside of your capacitor board? I would like to see how the stand-off's look. (probably just as neat as the rest)
    Thanks!
    a
  8. shortcircuit
    North Carolina
    Nothing special. I used a small round file to get the holes to fit the leads. After soldering, I hot-snotted the caps for extra support. The scrape marks on the top two empty holes were from me yanking out the turrets.
  9. shortcircuit
    North Carolina
    Power amp wired up. No cathode resistor yet. I got a bunch of 5W resistors from 360 ohm to 560 ohm to test to set the final bias. The power supply is in, and the voltage divider for the elevated heater supply is wired up. Also, the 2 protection diodes (UF4007) are in place.
  10. bigguy12321
    Traverse City Mi.
    Thanks! And that's the underside of the board... Sheesh!!!
    I have got to step up my game. This inspires me.
    a
  11. flyswatter
    flyswatter Friend of Leo's
    Quebec
    Nice work! I like the way you use those little handcut turret boards to tame the necessary connections and provide a good hybrid between true p2p and turret-mounted components.
  12. robrob
    United States
    Very nice point-to-point work. Looking forward to fire-up.
  13. shortcircuit
    North Carolina
    Got back from a weekend get-away with the missus. Finished up the wiring. I clipped in a 560 ohm resistor for the 6V6 to be on the safe side. With the power tube I had in there, it was dissipating about 10W. Nice clean sound, but I haven't cranked it up as it is late. It turned out that I didn't need any resistors for the filament (it's at 6.45V), so I jumped the turrents with copper wires. Tomorrow, I will play with the bias for the power tube. The schematic is as below. Nothing too nutty, but I'm planning a push-pull version with a 6SN7 as a LTP phase inverter.
    Oops, the grid stopper for the 6V6 should be 1K5. I also got the B+ coming out of the wrong node. You guys/gals know where it should go.
  14. shortcircuit
    North Carolina
    I spent the last couple of days playing with the little guy. First, I measured the plate and screen currents of all of my 6V6 and 6P6S tubes. I settled on 470 ohm as the cathode resistor, giving me a plate dissipation of 10.6 W and keeping the plate voltage above 300 V. After running the amp a bit, I remeasured the voltages, and the 6.3 V rail had crept up to 6.54 V, so I soldered in two 0.1 ohm resistors, bringing the voltage down to 6.33 V.
    The 6SJ7 tube was a bit microphonic, but it did not cause too much trouble as the chassis was mounted on a piece of plywood with rubber isolating feet. I had gotten a pair of 6SJ7WGT from ebay and tried them. The one that worked was also a bit microphonic. The other one was dead. The filament was open. The tubes were supposed to be NOS, and visually were in excellent shape. I carefully took off the metal shield and everything looked good. I reflowed and added some solder on pins 2 and 7, and voila, it came back to life. I couldn't get the metal shield back on tight enough so it rattled a bit. I glued it down with a generous amount of high temperature RTV silicone adhesive. After the glue set, I cleaned up the tube and plugged it in. No more microphonics! The silicone adhesive must have acted as a dampener.
    I think I'll change the LED to a red one to match the switch cover.
    The amp sounds nice and twangy. It's reminiscent of some of the older amps demonstrated by Uncle Doug in his videos. When the gain and the volume are cranked, the amp breaks up nicely with a fuzz tone that sounds a bit like the germanium Fuzz Face that I'd built.
    I tried a set of Soviet tubes--6N9S, 6J7, and a 6P6S. The 6J7 was also somewhat microphonic, but better than its American counterpart. The overall sound with the Soviet tubes was a bit bright with a glassy edge to it. I prefer the warmer American tubes.
    Here is the corrected schematic:
    Now on to the next build!
  15. D'tar
    D'tar Tele-Afflicted
    WNY
    @shortcircuit
    That's a fine little amp right there! Excellent job! I would love to hear it.
  16. robrob
    United States
    That is a beautiful amp, inside and out. I love the covered safety switch. Your photography is also top-notch.
  17. LudwigvonBirk
    LudwigvonBirk Tele-Holic
    Madison
    Looks super nice, well done.
    Suggestion (safety thing): add a grommet to the PT hole.
    robrob and D'tar like this.
  18. Preacher
    Preacher Friend of Leo's
    Big D
    Brings back memories eh? I love it as well! Has that Top Gun look to it!
    robrob likes this.
  19. robrob
    United States
    ^Good catch Ludwig, a grommet is definitely needed there.
  20. LudwigvonBirk
    Madison
    Also (again safety thing): I would suggest adding a drop of Loctite to the nuts. Maybe you already have and it isn't visible.
    Ex: Don't want these vibrating themselves loose! :
    shortcircuit likes this.
