That's it; I want a piney!
Discussion in 'Tele Home Depot' started by Telemaestro, May 12, 2017.
  1. Telemaestro
    Telemaestro Tele-Meister
    457
    Sep 20, 2013
    Hartville, Ohio
    Just extra precaution. If there is any visible glue line, I want it to be hidden, and blend with the color of the carbon fiber.
    And then I re-read your comment... I just used a couple drops of black leather dye. Haha
    rz350 likes this.
  2. Telemaestro
    457
    Sep 20, 2013
    Hartville, Ohio
    I couldn't resist flushing up the carbon fiber rod just to get a look at how it's going to look! I think it's going to look pretty sweet. I'll be doing a 1" V carve on the neck. So that's probably my next step. I'm pretty excited to see it carved.
    I'm going to use these brass threaded inserts, but I'm going to wait to install them until I cut the neck joint, I don't know why, but I want to do it that way, I guess.
    Daniel94, Mat UK and rz350 like this.
  3. rz350
    rz350 Friend of Leo's Silver Supporter
    Nov 15, 2009
    Waubeka Wisconsin
    Thanks, I'll remember that trick for epoxy! :)
  4. Telemaestro
    457
    Sep 20, 2013
    Hartville, Ohio
    So, tonight I made this slick little fixture for drilling my side dots on the CNC router, but, in a moment of sheer stupidity, I made it backwards!!! Which would be great if I were making a left handed guitar... live and learn, right? I'll be honest, I don't have a lot of blunders like this in building guitars anymore, so when I do, it's always humbling, and knocks me down a notch, which is always a good thing.
    Cheers!
    -Austin
  5. Telemaestro
    457
    Sep 20, 2013
    Hartville, Ohio
    Good news! I got my fixture modified this morning, and it works flawlessly. Drilled two different sizes side dots in 7 necks in about 10 minutes. The white dots are 5/64" and the black dots are 3/32" for some reason. Now I'm ready to drill my multiscale neck once I make a quick modification to the program.
    That's all!
    -Austin
    Daniel94, Mat UK and adirondak5 like this.
  6. Telemaestro
    457
    Sep 20, 2013
    Hartville, Ohio
    I finally drilled the side dots in my neck today. I'm going to try to carve it tomorrow.
    I use acetone for installing plastic side dots.
    Just dip the end of the rod in the acetone for a few seconds.
    Push it into the drilled hole.
    Clip it off a bit above the surface.
    The dots will get flushed up when the neck is trimmed to its final profile size.
    A little progress at a time. She'll be done eventually. Hopefully sooner than later. I really miss playing guitar.
    -Austin
    thegaijin, Mat UK and awasson like this.
  7. Telemaestro
    457
    Sep 20, 2013
    Hartville, Ohio
    I built myself a new spraybooth for spraying waterbased finish here in my home shop. Now I can finally get around to finishing up my guitar!
    -Austin
  8. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Oct 23, 2011
    Lynchburg Tennessee
    Can we have details on the spray booth? It looks great.
  9. Telemaestro
    457
    Sep 20, 2013
    Hartville, Ohio
    It's basically a doored cabinet with three box fans, two 4' LED lights, and it's lined with fiberglass reinforced plastic. The whole thing is on wheels, and rolls up into my doorway, I open a window on the other side of the shop for intake air.
    richa, Mat UK and awasson like this.
