Join TDPRI Today
Thanks Jack Wells and all of you at TDPRI
Discussion in 'Tele Home Depot' started by BluesBlooded, Nov 28, 2012.
  1. BluesBlooded
    BluesBlooded Friend of Leo's
    Oct 11, 2012
    Sherbrooke, Qc, Canada
    So, I'm building my first guitar.
    The neck is almost completed so I made a template for the neck on the ROSS
    Then routed the pocket. The results were so so!
    At first I was kind of OK with it being my first build. I was telling myself that the next one would be better!
    Still, I was unhappy with it. Could not resolve myself to leave it this way. I was contemplating making a new body.
    Then I found Jack Wells's post about making neck pocket template
    http://www.tdpri.com/forum/tele-home-depot/283103-**-making-neck-pocket-template-**.html
    So I decided to glue some wood back
    Then made the new template.
    Routed the pocket and installed the template over the body
    Then test fitted
    There is still a little gap on the treble side, but the neck fits tightly and this is much better for a first build
    This is why I'm thanking you all and specially Jack Wells
  2. Fred_Garvin
    Fred_Garvin Tele-Holic
    630
    Feb 21, 2011
    Atlanta, GA
    Excellent work. I suppose it's not critical, but it's a great feeling to get things to fit together well. At least at my skill level, anyway. I'll second you that the unselfish advice and encouragement of guys like Jack and everyone else here has been instrumental in my learning. Thanks to all of you.
  3. Nick JD
    Nick JD Doctor of Teleocity
    Where is Jack these days?
  5. J Lacey
    J Lacey Tele-Holic
    871
    Jul 19, 2006
    North Georgia
  6. Mike Simpson
    Mike Simpson Poster Extraordinaire
    Mar 19, 2006
    Gilbert, AZ (PHX)
    If you get the neck pocket too tight you will have to scrape the finish off the neck to put it together....
  7. Davecam48
    Davecam48 Friend of Leo's
    Dec 31, 2009
    Queensland Australia
    Beware Jack Wells content!!!!!!
    Don't start that again! :p
  8. Crafty Fox
    Crafty Fox Tele-Holic
    846
    Nov 25, 2011
    Perth Australia
    "Jack lives here".
  9. Davecam48
    Dec 31, 2009
    C'mon Jack they're calling ya! ;)
  10. TRexF16
    TRexF16 Friend of Leo's
    Apr 4, 2011
    Tucson
    That's a fact. I made my first the same way and it ended up being a lot of work to get it to fit after the neck and body were both finished. And there is a lot of potential to chip the lacquer on the body while try fitting the neck during the process. I think a small variation on this technique would be to put maybe two layers of masking tape on the sides of the unfinished neck, where it will bear in the pocket, to simulate the effect of finish on the neck and body, and then proceed exactly as you did making the template.
    So is two layers the right amount? Anybody have a better idea? I haven't had a chance to try it yet but intend to on my next build.
    Thanks,
    Rex
  11. BluesBlooded
    Oct 11, 2012
    I will use tung oil on the body and neck. It should not be as thick as paint and lacquer.
  12. Olav
    Olav Tele-Afflicted
    Apr 2, 2010
    HLMRmeer
    Funny how your neckpocket wasn't as tight a fit as you'd expect using the method you did to make a template. Are you sure the wood you clamped to the side of the neck was square?
  13. BluesBlooded
    Oct 11, 2012
    If you mean the gap on the treble side, I don't know why it is not as tight.
    I installed a stewmac 12in radius fretboard. I remember when I routed the fretboard to fit the neck that I could not keep the neck square on the router table. I think that the neck side is not 100% square with the bottom.
    next time I will use a top bearing flushtrim router bit and put the back of the neck on the router table instead of the fretboard.
    does it make sense?
  14. guitarbuilder
    guitarbuilder Doctor of Teleocity
    Mar 30, 2003
    I wonder if sanding the template on the OSS as opposed to flush trimming created the problem with the original template? Maybe more of a margin for error with less precision?
  15. BluesBlooded
    Oct 11, 2012
    Strange I'm quoting myself!
    I took a of picture of the neck and like I suspected, the side of the neck is not square. This is why I still have a gap on the treble side. The bass side is perfect.
    This proves that next time I will route the fretboard with the back of the neck on the router
  16. Bentley
    Bentley Friend of Leo's
    Jul 25, 2012
    Kelowna B.C, Canada
    When i routed i also had to route with my fretboard down, but i had already cut out and template routed the neck blank. If you know what i mean...
  17. BluesBlooded
    Oct 11, 2012
    Thanks Bentley, great idea, but I do you get it not to rock on the radiused fretboard?
  18. adirondak5
    adirondak5 Poster Extraordinaire
    Oct 24, 2009
    Long Island NY
    You trim routed a radiused fingerboard to the neck with the fingerboard down on the router table ?
  19. jkingma
    Admin Post
    Post some construction pics from when you made the neck and maybe we can figure out what happened.
  20. BluesBlooded
    Oct 11, 2012
    exactly:rolleyes:
    Rookie mistake.
  21. adirondak5
    Oct 24, 2009
    Long Island NY
    Well , mistakes are good learning experiences , and we all make them , but yea , flat surface on the router table or under the router base is the safe proper way to go , I don't radius my fret boards until after I flush trim them to the neck , but you used a pre radiused board so yea , the back of the neck down would be the way to go .
