Telemaster build
Discussion in 'Tele Home Depot' started by Tele-brewer, Apr 19, 2012.
  1. Tele-brewer
    Tele-brewer Tele-Meister
    114
    Apr 15, 2009
    Mogi das Cruzes, Brasil
    So I've started to build me a Telemaster. It's my second build. I've started a few months back, had to make a pause and now I'm making progress again.
    The body is Marupá, neck and fretboard are Marfin, all brazilian woods.
  2. Tele-brewer
    114
    Apr 15, 2009
    That's when the whole body/neck alignment debacle started. :confused:
    I thought there would be no difficulties to it, that I would just align the body and neck, mark, drill, assemble and that's it.
    I've even tried that:
    Turned out I had to try over and over. And I still didn't get it. At least I'm not confident to do it to actual guitar parts. I want to nail it with the templates and be able to reproduce them accurately.
    I'll have to come back to that.
  3. jnepo1
    jnepo1 Tele-Meister
    420
    May 31, 2010
    Sutton, Ma
  4. Jupiter
    Jun 22, 2010
    Osaka, Japan
    There's more than one way to skin a cat.
  5. Tele-brewer
    114
    Apr 15, 2009
    No, it's not.
    That's right. A belt sander.
    With an orbital sander it would take about a week. :lol:
    It's an alternative, since I don't have a belt sander.
  6. Jupiter
    Jun 22, 2010
    Osaka, Japan
    Some guys use a rasp.
  7. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    That tummy cut came out nice. When I saw you going at it with a saw, I had my doubts, but it looks great.
  8. dr_zaius
    dr_zaius Tele-Meister
    421
    Mar 22, 2011
    Livingston, Texas
    That's how I do mine. Rasp out the basics of the contour, then I use the drum sander attachment on my power drill to flesh it out a little more, then I spray cheap rattlecan red on the contour and sand with 80 grit on a flat stick in a cross hatch pattern until all the red is gone. Takes about two hours to do it that way, but it yields good results. Heck, judging from the pictures, doing it with a saw works pretty good too :)
  9. Blacque Jacque
    Blacque Jacque Tele-Meister
    104
    Nov 5, 2010
    Cambridge, UK
    Last time I did the belly cut I went with the 4 1/2" angle grinder with a 36grit sanding disk. It took me about an hour to get a good basic shape in hard maple.
  10. Tele-brewer
    114
    Apr 15, 2009
    Thanks a lot.
  11. Tele-brewer
    114
    Apr 15, 2009
    Thanks a lot, too.
  12. Tele-brewer
    114
    Apr 15, 2009
    Okay!
    Time for the binding rout.
  13. Tele-brewer
    114
    Apr 15, 2009
    And for gluing the binding.
  14. Tele-brewer
    114
    Apr 15, 2009
    Woops! :eek:
    That's the same spot.
  15. Tele-brewer
    114
    Apr 15, 2009
    That's the spot I screwed up. I actually got worse, cause the gap got filled with binding dust.
    This is another spot, at the other horn, that didn't turn out very good.
