Telecaster build project
Discussion in 'Tele Home Depot' started by JCL50, Aug 5, 2017.
  1. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    I'm currently building a Telecaster with a strat neck and a strat neck pick up.
    The objective is to have a classic-but-not-so-classic Tele for rock and country with maybe a hipshot b-bender.
    the pickguard will be copied heavily inspired after this one I had viewed on this forum
    So far, I've built the body (a few years ago and it needs a little work), found a used strat neck, already had the neck pick up. I have the pots and selector.
    I still need to order the bridge and the bridge pick up.
    I think I'll go for a Wilkinson Top load. Any good or bad experience with it?
    I'll have to fill the holes i had drilled :confused:.
    For the pick up i want a cheap vintage overwound type. I think GFS or Iron gear?
    brownale99, waltschwarzkopf and MM73 like this.
  2. waltschwarzkopf
    waltschwarzkopf Tele-Meister
    145
    May 17, 2017
    Zürich
    Cool! Tele body + Strat neck is one os my favourite combinations. Can‘t wait to see it finished!
  3. HairyChapter
    HairyChapter TDPRI Member
    53
    Feb 11, 2014
    Göteborg, Sweden
    Sorry, no experience with top loaded Wilkinson, but I have used the stringthrough Wilkinson on several guitars and think the work great for the price.. If you have holes drilled for string through I would use them.. Just my opinion.. Cool looking guitar any way..
  4. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    I've received parts this week.
    For the bridge pick-up, I've decided to try GFS, and for the bridge, a wilkinson (by xxxxxx) convertible (string through and top load both possible)
    I'm still trying finishes on scrap wood.
    I'll post photos as the project progress...
  5. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    Little by little, mistake after mistake :) (not so many). It looks OK to me.
    I've chosen the finishing : amber yellow with medium brown pore filler.
    The neck fits OK, The pickguard looks OK (not perfect but but can be fixed ) and I haven't drilled the neck pick-up hole yet.
  6. William SantAna
    William SantAna Tele-Meister
    141
    Aug 22, 2017
    Brazil
  7. ndeli55
    ndeli55 Tele-Afflicted
    May 12, 2008
    oklahoma
    Too bad you weren't building an offset that pickguard would go nicely
  8. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    Trial assembly: everything seems to fit nice and snug.
    A photo "in context": I think it's going to look cool.
  9. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    I've ordered the B-Bender (Hipshot B & G bender and D tuner), I hope I'll learn how to play with that thing.
    Yesterday it was sanding day. Today, it was staining (amber/yellow) :
    fenderchamp, Ekko and Robert.II like this.
  10. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    2 photos today while the sanding sealer is drying
    The ash shows a few nice flames
    Ekko and mkster like this.
  11. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    Today, I did the pore filling with stained mud joint compound. didn't take photo, it looks too ugly right now. :(
    but look what was in the mail today :)
    Steveinthesticks and Mat UK like this.
  12. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    After sanding, sanding and a little bit of sanding, I can say sanding is not my favorite part of this build o_O.
    Now it's time for the first clear coats:
    I'm a little disappointed by my pore filler that looks good on the small veins but looks way too greyish on the large ones :(.
    The back shows beautiful flames :)
    Ekko likes this.
  13. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    I've decided how this guitar will be wired.
    4 positions switch classic wiring except I've switched pos 3 and 4 so the positions that I use the most, Neck alone and Bridge alone are like on a 3 way switch Tele and easy to get.
    This way I will have :
    Pos 1 - Bridge
    Pos 2 - Bridge and Neck in parallel
    Pos 3 - Bridge and Neck in series
    Pos 4 - Neck
    Maybe I'll tweak the tone cap or treble bleed values but it should be something like that:
    Ekko and callasabra like this.
  14. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    While the clear coats are curing, a little soldering.
    Not professional looking but it should do the job. I'll just have to wire the pickups and the ground wire from the shielding when it's done.
    I haven't soldered the treble bleed as I plan to experiment with different values.
    Ekko likes this.
  15. Bristlehound
    Bristlehound Tele-Afflicted
    Jan 4, 2017
    Wales
    Lookin' good.
    JCL50 likes this.
  16. callasabra
    callasabra Tele-Afflicted
    Apr 11, 2016
    I have a similar 4 way except my 2 and 3 are reversed from yours. It us a nice progression from neck to bridge.
  17. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    I have a little concern about the in 2 p-u's in series position as my neck p-u is pretty hot.
    The GFS tele bridge pick-up is 7.2 k. The Bill Lawrence neck pick-up is 10.9 k. I hope they won't sound too muddy in series.
  18. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    One more week to wait before wet sanding, buffing and final assembly.
    I couldn't help test fitting (placing parts without screwing them on) to have a preview of the approaching end result.
    Maybe a little too orange and the filler is too grey but all in all, I'm not too far from what I wanted :)
    and the back is nice too
    and I will certainly put pin-up decals on it
    Now I just can't wait to know how it's gonna sound ;).
    reddy2300 likes this.
  19. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    2 photoshops of what my pinups should look like:
    It looks cool or not?
    Minimalist518 likes this.
  20. JCL50
    JCL50 Tele-Meister
    131
    Jul 31, 2017
    France
    wet sanding. 600 almost done.
    dickjonesify and Ekko like this.
