Telecaster Bigsby
Discussion in 'Telecaster Discussion Forum' started by mdb74, Feb 3, 2019.
Tags:
  1. mdb74
    mdb74 TDPRI Member
    Perth, Australia
    Hi,
    A buddy was telling me about a Bigsby that sits on a regular Telecaster bridge with no screws ito the guitar.
    Are these any good?
    Thinking of putting one on an AO 60s Telecaster
  2. FenderLover
    FenderLover Friend of Leo's
    Minnesota
    There are several products offered by Vibramate. I have three different models installed, they are solid and work well.
    mdb74 likes this.
  3. FenderLover
    Minnesota
    double post...
    mdb74 likes this.
  4. Garruchal
    Garruchal Tele-Meister
    Seattle
    I have a Vibramate V5 kit on my Tele, and I love it. Since I'll probably never take it off, I guess the only reason for a Vibramate is to transfer it to another tele, if I decide to change my number one, which isn't likely.
    My kit came (used) with the Vibramate bridge, and the plate which the Bigsby is attached to fits into two slots on that bridge. I am not sure that you can use your original bridge with a Vibramate; searching just now didn't answer that question for me.
    mdb74 likes this.
  5. BorderRadio
    Phoenix, AZ
    I’d say go for it, just screw it in. Saves you cash.
    The V5 is a good design though, and I appreciate stuff from Towner and Vibramate. Here’s the hardware for the Vibramate system. Seems legit.
    mdb74 likes this.
  6. E5RSY
    E5RSY Poster Extraordinaire
    Georgetown, TX
    Clever.
    BorderRadio and mdb74 like this.
  7. knavel
    knavel TDPRI Member
    London
    IMG_1106.JPG You would need to use Vibramate's hardware under the saddles because the plate the Bigsby sits on has two tags that slip into it for stability. Here is an F Bigsby on a Vibramate that I had going on my Telecaster for a few years.
    One little surprise was that my Vibramate plate under the Bigsby did not set right into the ashtray because (mid-70s) Fender did not put the rear strap button on the center of the base of the guitar! I had to drill a slightly off-center hole in the Vibramate base to get the unit to work.
  8. E5RSY
    Georgetown, TX
    How difficult is setting/adjusting the intonation screws?
    mdb74 likes this.
  9. knavel
    knavel TDPRI Member
    London
    It's been so long I don't remember, unfortunately.
    mdb74 likes this.
  10. BorderRadio
    Phoenix, AZ
    Adjusting these setups can be a pain. I notched my screws on the opposite end so I could easily turn them with a small flat-head screwdriver. I used a Dremel. Vibramate offers a saddle set with similar notched screws.
    E5RSY likes this.
  11. MMike
    MMike NEW MEMBER!
    Holland MI
  12. fendrguitplayr
    fendrguitplayr Poster Extraordinaire
    Greater Boston
  13. telejay
    telejay NEW MEMBER!
    pa/nj
    I put a Bigsby B5 w/ a Vibramate V5-TEV on my Baja Tele a couple of days ago. All went well but intonation proved to be difficult.
    Either go with BorderRadio's advice (notching), buy a set of dual access saddles (at StewMac for $50) or do the following:
    Install the Vibramate, then set the intonation BEFORE you screw the four Bigsby screws all the way down. Lift up the Bigsby to give you just enough room to reach the three intonation screws with a long screw driver. The strings have to be in place but not all the way tuned up. That would put too much pressure on the Bigsby. Then loosen all the strings to a minimum and tighten the 4 Bigsby screws. Tune up and you are ready to go.
    Tip: Before you start, take a picture or make a mental note of the location of the saddles before you remove them from your old plate. This will help you to get a rough idea where to position them on the Vibramate.
    Before I get any flak from anybody, this is only a suggestion and it worked for me perfectly.
    On a different note, the tone of your Tele may change. (There's a video on youtube, I think.) It did on mine, and I like it. Has a touch of a Strat tone now (to my ears), but just a touch...
  14. E5RSY
    Georgetown, TX
    Thanks. All good info. Appreciate you chiming in.
    Question: Why would you expect any flak (and congrats on spelling it correctly) from relating your personal experience?
    Scott
  15. telejay
    telejay NEW MEMBER!
    pa/nj
    Just a precaution. Personal experience or preferences may differ and not everybody is willing to accept that.
    (BTW, love your Muddy Waters quote.)
    E5RSY likes this.
  16. horseman308
    horseman308 Tele-Holic
    US
    As an alternative, I pulled the string posts and drilled all the way through, following up with a mild countersink. Works SO much better for string changes.
    Sent from my SM-G930P using Tapatalk
  17. Naigewron
    Naigewron TDPRI Member
    Norway
    There's also the Stetsbar, which requires no extra drilling.
    Technically it's probably a better engineered solution, but most people (me included) don't like the look of it. Or rather, we're more used to the look of a Bigsby-style vibrato system.
    http://www.stetsbar.com/
