Tele and Wolf of Baltic Birch plywood
Discussion in 'Tele Home Depot' started by gangreen, Apr 17, 2016.
  1. ndeli55
    ndeli55 Tele-Afflicted
    May 12, 2008
    oklahoma
    I'll offer the mad props, that is too fradukin' neat.
  2. gangreen
    gangreen Tele-Afflicted
    Aug 4, 2012
    Montrose, Colorado
    Wondered if and when this might happen. Thicknessed the neck and the patches of vertical grain tore out on the sides.
    Not something I'd like to repair. So.....the maple and Ebony neck initially destined for the hackberry Tele will now go on the plywood Tele.
  3. gangreen
    Aug 4, 2012
    Montrose, Colorado
    The 19 unaltered slats weighed 4750g.
    After the holes and channels were done it was 3650g.
    With Titebond it was 4000g.
    Shaped and sanded (edges and faces) with no cavity routed down to 2500g.
  4. gangreen
    Aug 4, 2012
    Montrose, Colorado
  5. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Wolf neck in place.
    DrASATele and HockeyPop98 like this.
  6. NotAnotherHobby
    NotAnotherHobby Tele-Afflicted
    Oct 27, 2015
    Da' Magic Mittin'
    What were you using to thickness the neck?
  7. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Table saw as usual to take off 3.5mm between the butt and head. Might have worked better to use the drum sander with a fence like I use to thickness the headstock. Live and learn.
  8. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Carved and sanded the backs of the necks and thinned the headstocks to 0.6" with a fence on the drum sander.
  9. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Oct 23, 2011
    Lynchburg Tennessee
    Those are looking good!!
  10. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Always nice when the hidden tunnels turn out to be where you had hoped they would be. It all seems to fit.
    LowThudd and I_build_my_own like this.
  11. Barncaster
    Very good progress. I remember seeing some old Teisco necks made up of laminations. Probably indestructible.
  12. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Recesses for cavity covers 1/4"deep. Jack hole drilled. Found the channel to the control cavity. I think that's it for making sawdust. Final weight for the body is 3.81 lbs.
    LowThudd likes this.
  13. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Cavities routed and tunnel found. Even 5# buck naked.
    LowThudd and LiteAsh like this.
  14. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Rounded. Sanded. Adding some poly.
    Barncaster likes this.
  15. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Frets in. Medium high nickel for the Wolf and medium nickel for the Tele. Removed tang barbs at the 22nd fret to prevent the strip between the fret slot and the spoke wheel recess from popping out.
  16. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Kahler fine tune bridge. Lace humbuckers. Floyd Locking nut. Variety of tuners. Made its first noises this morning.
    LowThudd and David_Maas like this.
  17. I_build_my_own
    Mar 9, 2012
    New York
    Someone gotta ask.... Can u elaborate the tuner choice?
  18. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Goal for this guitar was to build it from as many leftover parts as I could get together. A few of the electronics are new but everything else already had in the shop. Four Grover tuners of various colors and two gold Sperzels. Calico?
  19. gangreen
    Aug 4, 2012
    Montrose, Colorado
    Plywolf is done.
    Won't be the last one of these.
    LowThudd, CraigB, Barncaster and 2 others like this.
  20. I_build_my_own
    Mar 9, 2012
    New York
    Looks great and the name Plywolf is even better!!
    HockeyPop98 likes this.
