Tele 4-way switch w/single + mini-hum neck pup wiring?
Discussion in 'Tele Home Depot' started by GorgeousTones, Apr 15, 2019 at 8:08 PM.
  1. GorgeousTones
    GorgeousTones TDPRI Member
    Boston
    Hey guys, I can’t find a wiring diagram for this specific setup. It’s a Fralin Blues special in the Bridge & A Seymour Duncan Firebird style mini-humbucker in the neck.
    -The majority of diagrams I could find describe the addition of 3rd lead to the neck pickup coming from the base or metal cover, I’m not sure.. But I think I remember reading that it’s not necessary for an uncovered neck position pickup??
    *The weird thing is the Fralin Bridge came with a 3rd lead, which is black and is soldered to the bottom baseplate. I’ve seen this before (for example when I bought a different Lindy Fralin single coil not part of a set) and I usually just ground it to the back of a pot like the other black lead and forget about it. I don’t think this is significant here but I figured I’d mention it just in case
    Anyway. Can anyone help me out with this I already tried wiring it a few different ways based on diagrams for pickup arrangements different than mine and couldn’t get it working right. Again it’s just a standard Tele single coil Bridge + A mini-humbucker with a shielded metal lead/two conductors if you count the grounded shielding.. Thanks guys!!
  2. archetype
    archetype Fiend of Leo's Silver Supporter
    Williamsville NY
    I'm watching this one, as I'm going to try a 4-way switch with a Firebird neck pickup and a '51 Nocaster bridge pickup.
  3. eallen
    eallen Tele-Afflicted
    I dont have one with your specific pups but I use this I drew up for all my SH builds. I lean towards Bill Lawrence's pups so that is what is drawn with duncan code listed. Your few number of wires on the mini HB likely won't have a coil split option so you would have to figure that option.[​IMG]
    Eric
  4. TRexF16
    TRexF16 Friend of Leo's
    Tucson
    Is your neck pickup this one, with a traditional Braided shield/ground, and a single hot wire inside the shield?
    https://www.seymourduncan.com/pickup/antiquity-ii-firebird-bridge
    And you have a bridge pickup with a separate wire that just comes off the baseplate?
    Then I think this may be what you want.
    The neck pickup shield goes to ground as the black wire in the picture above. I think the base plate wire from the bridge pickup becomes the green one. But I am not looking at your rig so I can't guarantee.
    Do the smarter guys here concur?
    Cheers,
    Rex
    eallen likes this.
  5. jimilee
    jimilee Tele-Holic Silver Supporter
    Chattanooga
    So, would the three pickups then act like a three coil pickup the way 2 single coil pickups would act like a single 2 coil pickup?
  6. eallen
    After reading Rex and rereading the OP, I'm not one of the smarter guys but I concur.
    I missed the single with a braid on the HB. The simple limit of the mini-bucker verses a full means it is basically treated like an SS wiring without an extra neck wire for the cover.
    Eric
