Swirls or scratches in tru oil
Discussion in 'Finely Finished' started by domanation, Feb 19, 2019.
  1. domanation
    domanation TDPRI Member
    detroit
    https://flic.kr/p/2eKVkcY[​IMG]
    I’m at a bit of a loss. Every time I wet sand I end up with these darkish swirl marks that I can’t even see until I put another coat of tru oil on. It was building nicely and I wet sanded with 1000 and put thinned our coats on only to find these. So I wet sanded with 600 unroll they went away put another coat in and they are back. Any clue how to approach this?
    Thanks this place is a wealth of information.
  2. eallen
    eallen Tele-Afflicted
    My 1st go to when something looks like this is either sanding before it is fully hardened or you aren't getting the marks sanded out from previous grits.
    Eric
    Sent from my SM-G892A using Tapatalk
  3. Matthias
    Matthias Tele-Afflicted
    Dirty sandpaper too... I have a bad habit of not cleaning the paper or surface enough when I’m wet sanding and end up scratching the surface with debris, which can get caught, especially if you sand too soon as eallen says.
    Chunkocaster and eallen like this.
  4. jimgchord
    jimgchord Tele-Holic
    victor,ny
    Dirty paper
  5. domanation
    detroit
    Yeah I thought that might be the case. Is the fix sanding back with like 320 to get them out?
  6. Silverface
    Lawndale CA
    It has very low abrasion resistance and the film build is the lowest of anything I can recall, as it's not really a "coating. It's being used as one - but that's not the product design intent nor a strength. It builds a small fraction of the thickness of lacquer, polyurethane; shellac, varnish etc.
    IMO the problem is wet sanding it at all. Apply it and leave it alone, or use a non-wax, non-silicone, buffing type polish like StewMac's Preservation - and with nothing but a clean, soft, cotton cloth.
    ALL wet sanding creates swirl marks - lacquer, when applied well needs no wet sanding, just buffing - eliminating the wet sanding is a huge advantage.
  7. lammie200
    lammie200 Tele-Afflicted
    San Francisco
    I think that you might have to buff it with rubbing compound between coats if you want that urethane gloss look.
  8. Chunkocaster
    Chunkocaster Friend of Leo's
    In space with Ziggy
    I use micro mesh and wet sand between the final coats. Never had a problem. Can't remember the grits but I work through about half of the stew mac pads excluding the most course grit and the extremely fine grits.
  9. RolandG
    RolandG TDPRI Member
