Sweet Little Angel
Discussion in 'Tele Home Depot' started by BluesBlooded, Mar 30, 2016.
  1. BluesBlooded
    BluesBlooded Friend of Leo's
    Completed the inlays, sanded the radius up to 800grit
    Had to fix some spots with ebony dust and CA glue
    It was a real pain in the kisser.
    I think the MOP is very thin at the top of the G.
    All in all, I'm very happy with the result.
    Kudos too all the inlay artist out there. You have all my respect.
    Next step, glue the board to the neck.
  2. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Oct 24, 2009
    Long Island NY
    That is some nice work there Andre , that looks great .
    BluesBlooded likes this.
  3. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Oct 23, 2011
    Lynchburg Tennessee
    That is just awesome. Great job with it!!
  4. BluesBlooded
    Thank you Herb and Rebel,
    I glued the fretboard, using the locator nails so it won't slip all over the place.
    Should be able to fret it tomorrow
    John Nicholas likes this.
  5. BluesBlooded
    While the glue was drying, I sanded the body to 150 grit
    The binding in the back is ok. Mainly due to the manual channel. There is some minor gap to fill.
    The front on the other hand is perfect.
    gap filled with some timbermate
    Release the neck from the clamps. used the triangle file on each fret.
  6. s_tones
    s_tones Tele-Holic
    860
    Nov 10, 2013
    central CA
    Excellent!
  7. BluesBlooded
    Thank you Steve, your guidance helped me a lot for those inlays. I did not get the air tight fit that you get, but this is due to the difference in the tooling size. I see now that the smaller bit you use would give a better fit.
    No matter the tool sizes, I'm sure there is still some manual fitting to be done, specially the tight corners like all your ww inlays. This is intricate work that require a good deal of patience.
  8. s_tones
    s_tones Tele-Holic
    860
    Nov 10, 2013
    central CA
    Yes, it's a finicky business for sure. Obviously a trade off on the bit size. smaller you go, the more they are prone to break.
    I've even noticed that the orientation that small parts are cut in can matter. Sometimes just turning the path 90 degrees will improve the fit.
    Whatever the case, WAAAAY better than the jeweler's saw! And honestly on a dark background it's so effective to fill the small gaps that an absolutely perfect fit is not really necessary.
    Looking forward to seeing this baby completed!
    Steve
    John Nicholas and BluesBlooded like this.
  9. BluesBlooded
    Tapped the end of the frets
    Pressed them in
    Four of them would not stay down. Had to resort to CA glue
    Cleaned the excess glue
    Sanded the frets end. ready for binding.
    Cut the pickguard out of 1/8 birch ply.
    And headstock faceplate
    Started the binding. I will go in steps since I have to cut the corners at angle.
    Not really sure how the binding will turn out.
  10. 2blue2
    2blue2 Friend of Leo's Silver Supporter
    Jul 20, 2013
    Island of Oahu
    Right on BluesBlooded, Its really starting to get there and its really neat .
    Just loving all the neat binding.
  11. BluesBlooded
    Thank you Jeff, It starts to look like a guitar. It's fun to be able to put lots of time on a project like this. You kind of get into a rhythm of progression that is very satisfying.
  12. BluesBlooded
    Been a slow week.
    started with the headstock faceplate top curve
    Then realized that with the sharp corners I would not be able to glue the binding by layers directly and achieve the proper angle.
    So I laminated some length of bindings. Shielded the wood from the binding with wax paper.
    Adding one piece per day, I'm almost there.
    The pickguard only had one sharp corner, so that went faster.
    All cleaned up and ready for paint.
    Also bound the neck and started to scrape away.
  13. RickyRicardo
    RickyRicardo Friend of Leo's
    Mar 27, 2012
    Calgary, Alberta
    This is great stuff Andre!
  14. nickhofen
    nickhofen Friend of Leo's
    Most excellent Andre!
  15. Blue Bill
    Feb 15, 2014
    Wow, Andre, everything about this guitar is spectacular. BB is beaming from up in heaven. The Merriest of Christmases to you and your family!!
  16. BluesBlooded
    Thank you Rob, Richard, Nick and Bill! Merry Christmas to you all and your family as well.
    Spent the afternoon nibling. Still a little bit of work to do. That will wait closer to the finish line.
  17. s_tones
    s_tones Tele-Holic
    860
    Nov 10, 2013
    central CA
    Nice nibbling! Gave me a sore neck doing that. It's tedious but somehow rather satisfying. And I do like the look.
    Steve
    pengo720 likes this.
  18. BluesBlooded
    Steve, you are right, it's tedious but looks great. I'm glad it's almost done.
  19. GunsOfBrixton
    GunsOfBrixton Tele-Afflicted
    Dec 9, 2011
    Rochester, NY
    Looking great Andre. I am not a big fan of the nibs but, they do go nicely with ebony.
