Swapping Mini HB for Firebird ?
Discussion in 'Just Pickups' started by steve v, Feb 10, 2013.
  1. steve v
    steve v Tele-Meister
    497
    Jun 18, 2009
    Eagle Mills, NY
    Right now, I have a Lollar mini HB in the neck of my Tele along with a Special T in the bridge. Sometimes I find the middle position tone to be a little thick for my liking and I was wondering what switching to a Firebird pickup would do. Any issue with fitting in the mini HB routing/pickguard ? Thanks
    edit - I should also add that I have been experimenting with lowering the pickup but raising the poles with some success, so I guess I'm just curious about the swap
  2. caliban335
    caliban335 Tele-Afflicted
    May 4, 2007
    Cleveland, Ohio
    I'd ask Lollar about the fit, if I were you. That said, they appear to share the same dimensions. The Firebird style will be a brighter pickup. The Mini will break up sooner. I've had both styles in the neck position of Teles in the past and liked them both.
  3. Southpaw Sam
    Southpaw Sam Banned
    108
    Feb 18, 2013
    OKC
    I agree as the Firebird uses a ceramic bar magnet talk about BRIGHT, and dependent upon whether or not the Mini HB utilizes A5 or A2 magnets also makes a difference as to break up, A2 breaking up quicker. Some tinkerers might just change out the A5 or A2 magnets themselves in their Mini HB (as in your case) or just buy another Mini HB pup with the preferred magnet type.
    Seymour makes an Antiquity II Mini HB that utilizes A5 magnets, and Seymour used to carry a stock Mini HB that utilized A2 magnets (but I couldn't find them on his website).
  4. kmac
    kmac Tele-Meister
    431
    Aug 15, 2010
    Plymouth, MA
    You need to widen the mini hb hole a bit.
  5. Teleterr
    Teleterr Friend of Leo's
    Feb 7, 2011
    Lewes De.
    My Firebird p/up from the '60s had dual single coils around an AlNiCo magnet set up for HB.They've changed to ceramic at Gibson. The old school ones aren't made by anyone ?
  6. brookdalebill
    Nov 15, 2009
    Austin, Tx
    You could lower your mini HB a little, and raise your
    bridge pickup.
    Might help with the middle position problem.
  7. steve v
    497
    Jun 18, 2009
    Eagle Mills, NY
    That's pretty much what I did, and with good results. Now the bridge pickup is a bit too bright on its own unless I roll the tone back. Time to order new tubes and build a new guitar I guess :)
