Supro build .
Discussion in 'Tele Home Depot' started by mkster, Jun 14, 2015.
  1. mkster
    mkster Tele-Afflicted
    Sep 25, 2010
    Montreal Quebec
    Now for the nut i have the lapsteel one , i wonder what it made of , it looks like bone . Its large enough but would be waist with a zero fret , then there is ebony .
    Marc
  2. mkster
    Sep 25, 2010
    Montreal Quebec
    With the neck bolted on , the action is really low there is some buzzing , i will have to wait because i would need to put the tuner ferules in to do a proper test. The bridge design is awful at holding stings i will have to install string trough ferules .
    Best regards
    Marc
    coonhollow greg and Barncaster like this.
  3. mkster
    Sep 25, 2010
    Montreal Quebec
    I decided at 4 am to do some Nitro , i will hit the end grain with a paint brush .
    fenderchamp and Barncaster like this.
  4. mkster
    Sep 25, 2010
    Montreal Quebec
    I am almost done , not really !I thinks its time to start a second one , white or sunburst ..
    Zepfan likes this.
  5. Zepfan
    Zepfan Poster Extraordinaire
    Nov 30, 2013
    Horn Lake, MS
    You have the sickness.
  6. mkster
    Sep 25, 2010
    Montreal Quebec
    Its a little crooked i need to fix it , i am doing the ferrules tonight.
    Barncaster likes this.
  7. mkster
    Sep 25, 2010
    Montreal Quebec
    The string spacing is different from a telecaster , i managed not to screw up too much .
  8. mkster
    Sep 25, 2010
    Montreal Quebec
    Ok its a little off to late now ...
  9. mkster
    Sep 25, 2010
    Montreal Quebec
    I started to complete the Supro necks , i so happy my fretboard joint is a lot better then a thought .
  10. mkster
    Sep 25, 2010
    Montreal Quebec
    I am afraid its terminal , there is no escape , my project are accelerating i don't have much time left .
    Marc
    kkphoto and Zepfan like this.
  11. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    I know the feeling.:rolleyes:
  12. mkster
    Sep 25, 2010
    Montreal Quebec
    After some test the neck is a little too high , i lower it and redid the rod access hole .
    Barncaster and Zepfan like this.
  13. mkster
    Sep 25, 2010
    Montreal Quebec
    That is the real color , i dont know why camera show it pink sometimes...
    guitarbuilder likes this.
  14. Barncaster
    I must hear this through a dimed Harvard.......
    mkster likes this.
  15. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Oct 23, 2011
    Lynchburg Tennessee
    Looks great!!
    mkster likes this.
  16. mkster
    Sep 25, 2010
    Montreal Quebec
    I dont know about Harvard but Princeton , i cant wait but its tricky the bridge pickup i am not yet sure if i will need to use the router on the neck pocket again .
    Thanks old Rebel !
    Best regards
    Marc
  17. mkster
    Sep 25, 2010
    Montreal Quebec
    I have learned something , the pink color the camera was picking up is now gone .
    So this was my first try at making paint from lacquer and pigment , at first i did not know if it would be opaque , the guy at karma pigment show me that its the type of pigment i choose that will make it translucent . I first thought i could get away with a thick layer of color layer since i used a brush to put it on , It was messy and need a incredible amount of wet sanding was needed and it looked like the paint frm budget Gibson like on the melody maker , that give me the idea of using a paint roll next time . I told my self if i could get away buffing the color and not putting on clear on it since its the same lacquer anyway .
    So i did , the pictures up there is exactly that i sanded trough the color in many spots , so i added 2 more color layer and clear on top about 5 days ago , first thing i noticed was the pink color is gone , i am pretty happy about that .
    I also rounded off the edges of the pickguard so it would look more authentic .
    There is a trick i use before starting to paint , i put candle wax in the holes and in the neck pocket .
    When i am done i can wet sand without being scared of raising the grain from the water . It also leaves the neck pocket clean , its so easy to remove .
    Best regards
    Marc
    Barncaster and guitarbuilder like this.
  18. Barncaster
    Wow that looks fantastic!
  19. mkster
    Sep 25, 2010
    Montreal Quebec
    The top and neck are are ready for final buffing , i will do the back today !
