Suitable Tools For Guitar Necks, and Cheap Wood for practice
Discussion in 'The DIY Tool Shed' started by Wind Gatherer, Mar 13, 2019 at 10:38 AM.
  1. Wind Gatherer
    Wind Gatherer TDPRI Member
    OK thanks am about to search the forum on shaping necks and this, facets method.
  2. guitarbuilder
    I have a thin rectangle and the curvy one. The curvy one doesn't see a whole lot of action, mostly scraping glue joints.
    Nickfl likes this.
  3. Mat UK
    Mat UK Tele-Afflicted Silver Supporter
    London, UK
    Poplar (Tulipwood in UK) is pretty cheap...
  4. D_W_PGH
    D_W_PGH Friend of Leo's
    Pittsburgh
    If you want to be able to use them if the turn out well, they need to be one hundred percent knot free and perfectly straight sawn regardless of whether or not they're quartersawn or rift sawn.
    If you're just practicing shaping, is try to find some wood that is similar to what you'll use. Eg, sycamore if you intend to use maple later, or khaya or sipo if you think you might want to use some kind of mahogany.
  5. Wind Gatherer
    Just reading your thread from March 2012, neck carving by drawing and creating facets on the wood.
    guitarbuilder likes this.
  6. Wind Gatherer
    Um, been reading guitarbuilders thread from March 2012, neck carving by drawing and creating facets on the wood. Though it might be quicker than using rasps, as in the Fletcher Guitars YouTube.
  7. Mat UK
    London, UK
    You might be best served combing all these questions and threads into one. it will be easier for all to follow. Try starting a build thread in the Tele Home Depot documenting your journey
  8. guitarbuilder
    Well if you don't fall asleep, there is probably enough info in there to make a neck....:).
  9. guitarbuilder
    I can't say many use a spokeshave and none that I recall over the years have used a drawknife. Popular tools are rasp and files, Surform type tools, razor files, and abrasives of one form or another. There are a couple grinder and belt sander folks.
    https://www.stewmac.com/Luthier_Tools/Types_of_Tools/Files/Razor_Files.html
    I even bought a humongous router/shaper bit for a hand rail to do it. That was scary.
    https://www.grizzly.com/products/Gr...MIrbym36OA4QIVDp7ACh3zTQkREAQYAiABEgIYMfD_BwE
    Only used it once.
    The problem that I experienced with a spokeshave ( guitar number 1-6) was how my poor technique caused dips that were really hard to sand out. That's when I bought my Ferrier Rasp. The wider cross section helps keep things flatter, at least that was/is my experience.
  10. Count
    Count Friend of Leo's
    Tenterfield, Australia
    I was taught to use a Drawknife by my Grandfather back in the early 60s, he was a Wheelwright and Coach Builder. I inherited and still use his main drawknife which was originally his father's, it has passed down through Gt Grandad, Grandad, Father to me. A drawknife takes a lot of practice to use properly and the ability to "read" timber is essential. That is, the grain pattern of the timber and the nature of the timber itself dictates how you use the knife. The size of the knife is largely irrelevant for a guitar neck but a smaller one, as shown, would be easier to control. However, once you can use a Drawknife properly and know how to sharpen it rasps, files, spokeshaves etc will take a back seat.
  11. Wind Gatherer
  12. Wind Gatherer
    OK thanks.
  13. Wind Gatherer
    Thanks for that.
  14. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    I bought one of these years ago, I know I paid nowhere near this price. I use it for final shaping heads on neck. It's also incredible tool for final shaping of guitar bodies most my guitars are one of a kind so making a template really not necessary, Plus not a big fan of those giant pattern bits. The spindle sander has turned out to on of those sleeper tools they just have so many uses great shop tool.
    https://www.amazon.com/dp/B00006JZZW/?tag=tdpri-20
  15. Wind Gatherer
    OK thanks.
  16. DrASATele
    North of Boston
    Doug Fir can be a good wood for practicing necks on. I like quartered Doug Fir for actual necks if I'm doing a barncaster or Pine style build. It makes a good test subject because the soft and hard grain/rings takes some patience to level and make smooth. You really need to pay attention when building a neck out of Fir, Spruce, Pine or the like because of the big difference between the hard and soft grains.
  17. DrASATele
    North of Boston
    That is a great thread.
    I had thought about building a gig for the ROSS to make the facets the issue I came across is heat. The oscillating belt sander part made the blanks to warm
    and they would slowly bow or warp as they cooled. It could have been that I tried to take too much off but I think it might have been the opposite in a way. I was taking longer trying to sand less material off but that cause the belt and the wood to warm up as I continued to shape the neck. I had the same issue with the router bits I bought. They heat up the wood so much that you run the risk on movement as it cools. However a good rasp, a few new scrapers and some sand paper and you can make a pretty stable, nicely shaped neck, it just take a bit of time. I do the facets with a farriers rasp and scrapers now. I get a nice stable, good feeling neck everytime.
    I agree I use the flat one and the weird curve one (goose neck I guess it's called). I also bought a set of scrapers at woodcraft with a slightly smaller goose neck, a convex/concave and a flat scraper. I paid the same for those 3 as I did the Stew Mac goose neck. I use the convex/concave one towards the end of the shaping.
  18. DrASATele
    North of Boston
    Although they are beautiful craftsman style tools, like said above, they require a wealth of knowledge and practice to achieve acceptable results. I have a spoke shave I got from my Uncle, it's a 40+ year old tool that I'm still working on my technique for. It will be awesome to use when I have the skill but for times sake anything that needs to be built in a timely manner gets the rasp and scraper treatment.
  19. Wind Gatherer
    Would this cabinet scraper set on Ebay UK be good to get? Item number 311833887900
  20. Wind Gatherer
    OK point noted.
