String Trees
Discussion in 'Squier Tele Forum' started by vanr, May 8, 2019.
  1. vanr
    vanr Tele-Holic
    AZ
    Why does my older Squier Standard Tele have 2 string trees and my new Squier Bullet Tele only has one? And should I add another string tree to the Squier Bullet Tele? Actually been trying to pull the trigger on the new 3-string tree I saw on Reverb.
  2. Scottz
    Scottz Tele-Holic
    Littleton CO
    I added a 2nd to my Bullet FSR the G string kept pinging.
    pontiacfan46 likes this.
  3. vanr
    vanr Tele-Holic
    AZ
    I just ordered the triple string tree I saw on Reverb. I'll give it a try.
  4. Chunkocaster
    In space with Ziggy
    Not sure but the last couple guitars I put together seemed fine with no string tree. One had staggered tuners the other normal vintage tuners. I fitted a single tree anyway just to be safe and not pop a sting out of the nut down the track.
    The change in tone was minimal if at all.
    I would only worry about the b and e strings.
  5. gkterry
    gkterry Tele-Meister
    Paris, IL
    Yeah, @Chunkocaster is right. Only worry about the b & e strings.
    BTW, @Scottz that pinging you heard was more likely the string catching in the nut slot.
    I would suggest using a lead pencil to put some graphite in the slots. That should reduce the pinging you may have heard and also allow the strings to more easily move in the slots.
    Chunkocaster and nojazzhere like this.
  6. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Go with just the e & b, use a spacer to lift it, assuming the one you have is low.
  7. vanr
    vanr Tele-Holic
    AZ
    Does anyone know why Fender/Squire puts 2 string trees on some models and just one string tree on other models?
  8. Scottz
    Scottz Tele-Holic
    Littleton CO
    No, it was the angle of the string
  9. monkeybanana
    monkeybanana Tele-Meister
    Dock of the Bay, Georgia on my mind.
    That's the Joe Glaser string tree. I put it on my AVRIs I do not want to drill.
  10. vanr
    vanr Tele-Holic
    AZ
    So my Glaser 3 string tree came in. Didn't even install it. Went in my parts drawer for now till I get to it.
