String Ferrule Issue
Discussion in 'Tele-Technical' started by Fendereedo, Aug 9, 2018.
  1. Fendereedo
    Fendereedo Friend of Leo's
    Just restrung my Nashville Tele, and when loosening off the strings and cutting them, the low E Ferrule popped out. Looks like the hole is slightly bigger than the Ferrule that fits inside. I added a dab of wood glue in then restrung the rest of the guitar. Is there a more permanent fix for this problem if it happens again? Thanks in advance
  2. adjason
    adjason Friend of Leo's Silver Supporter
    virginia
    sorry not much help- I've had teles that this happened to. I so rarley change strings that I don't worry about it
    skunqesh and Fendereedo like this.
  3. Smiff
    Smiff Tele-Holic
    It won’t drop out when it’s strung up and under tension. Just don’t lose it while restringing and you’ll be fine.
    RodeoTex and Fendereedo like this.
  4. Preacher
    Preacher Friend of Leo's
    Big D
    a little super glue will work as well. It just means your tele is drying out a little and getting more mojo!!
    StrBender and Fendereedo like this.
  5. Fendereedo
    I think I will go the super glue route next time I change strings. Thanks all! ;)
  6. Beech Creek Gary
    Beech Creek Gary TDPRI Member
    Hawkins County, Tennessee
    Clear nail polish will work too.
    Fendereedo and RodeoTex like this.
  7. skunqesh
    skunqesh Tele-Meister
    West Coast
    this seems to be a common problem of older teles - body drying/ferrules slipping out.
    side story
    long time ago (20+ years) my '73 Tele Custom dropped a couple of ferrules.
    So I go over to the local geetar shop and look for new ones.
    Shop keeper says 'bring me your old ones I'll give ya new ones free'
    Me, being mostly broke and young and dumb, did just that.
    My 2c - at the time it was probably a fair trade, but now knowing that they were worth more as OEM parts, and said chop shop keeper was taking advantage of my naivete', I would recommend anyone with a 'vintage' or classic guitar to consider a dab of wood glue.
  8. strat a various
    The wood glue will hold them fine
    Fendereedo likes this.
  9. heltershelton
    heltershelton Tele-Afflicted Silver Supporter
    not houston
    you could also wrap masking tape around the ferrule, cut off the excess, and tap it back in.
  10. Chiogtr4x
    Chiogtr4x Friend of Leo's
    Manassas Park, VA
    Two threads about Tele ferrule issues!
    I never knew about this little headache, till today.
    I've owned 3 Teles ( back to mid '80's ?) and no loose ferrules; the Superglue or fingernail polish fix seems like a good idea.
    Always learning...
  11. Fendereedo
    Yes, seems to have worked fine. I only used a small amount on a cotton swab. Worked just fine.
  12. Jim622
    Jim622 Tele-Afflicted Silver Supporter
    Far N.E. Philadelphia
    I always just fed the string through the ferrule then the body, and let tension keep it in place.
  13. JL_LI
    JL_LI Tele-Afflicted
    Long Island, NY
    I'd avoid super glue. Cyanomethacrylate outgasses as it cures. It leaves a residue that is VERY difficult to remove on anything the vapor comes in contact with. It will be noticable on glossy finishes. I'd put a thin film of 5 minute epoxy inside the hole next time I restring. There is nothing in epoxy adhesives that outgasses. Press in the ferrule and wipe away any residue. Don't restring through that ferrule for a few hours. A string that can't be removed is a much bigger problem than a ferrule that slips out.
    Jim622 likes this.
