String buzzing
Discussion in 'Tele-Technical' started by nashd, Nov 25, 2013.
  1. nashd
    nashd TDPRI Member
    59
    Oct 21, 2003
    My top E string is buzzing. It sounds a bit like a sitar, and if I fret each note, it doesn’t vary a huge amount – they all make the same sort of noise. The other strings are fine. When playing through an amp it’s quite a ringing noise, and if I twang the bass strings in an open E chord the top E seems to resonate and starts ringing even though my fingers are nowhere near it.
    It’s a nice quality guitar which was well set up when I got it, and it’s got a hefty maple neck, but I haven’t played it much before – still on the original strings. It’s not been subject to any variation in temperature. I suppose it’s just needing a minor tweak, but I’m not sure if the saddle needs to be raised slightly (it’s got titanium compensated saddles), or if it might need a truss rod tweak.
    I probably won’t attempt anything myself – I’ve never been able to work out how to fix guitars, but from past experience there’s no-one local to me I’d trust. I’ll probably have to book up to take it somewhere ‘reputable’ but it’d be good to know what it might be needed before I arrange anything.
  2. jbmando
    jbmando Poster Extraordinaire
    Yes, it sounds like the high E saddle has to be raised. This really is a user adjustment. You should not have to go to a tech to raise a saddle.
  3. PaulStrattele
    PaulStrattele Tele-Holic
    788
    Jun 18, 2013
    WNC
    I had a Tele that had the same issue. Thought it was the nut for the longest time. It ended up in the saddle. You can fix it.
  4. nashd
    nashd TDPRI Member
    59
    Oct 21, 2003
    Thanks. If it's just the saddle height then I might have a go at this myself.
    Will raising it very slightly mean the intonation will go out?
    Also, what effect will it have on the B string (with the compensated saddle)?
  5. jbmando
    No, intonation should not be affected by raising the saddle a little. If the B string gets too high, lower the B side of the saddle If you look at the saddles from the strap button end, they should follow the radius of the fretboard. I'm guessing your E/B saddle is too low on the E side.
  6. soulman969
    Mar 20, 2011
    Englewood, CO
    I'd also suggest looking at how the string sits in the nut especially since it's the high E. That sitar like buzz you describe may sound like it's coming from the saddle but often the problem is in the nut because the string has cut into it too deeply and it's sitting too low.
    One approach to fixing the problem without replacing the nut (probably the only permanent solution) is to put a very small piece of paper or cloth in the string slot so it raises the string off the bottom of the nut very slightly. If the buzz goes away that where your problem is coming from.
    One of my Teles has that problem with the G and D strings depending on the strings I was using at the time. A small bit of paper in the slot took care of it until I could recut a nut.
  7. Chritty
    Chritty Tele-Afflicted
    If it's a bone nut you can mix some bone dust with some super glue to make a paste and refill the slot. I saw a video on YouTube of Dan Erlewine doing just that. Although it might have been a different material but I seem to remember it being bone. It's a cheap quick fix compared to a new nut
  8. soulman969
    Mar 20, 2011
    Englewood, CO
    Hadn't thought of that fix Chris. Good idea if he has some files to cut a new slot with.
  9. Chritty
  10. nashd
    nashd TDPRI Member
    59
    Oct 21, 2003
    In which direction should I turn the height adjustment screw in order to raise the saddle? Also, do I need to slacken the string before making the adjustment?
  11. kurtmanifest1
    kurtmanifest1 Tele-Meister
    302
    Oct 17, 2013
    Argentina
    If it doesn´t go away by raising the saddle check if the string isn´t touching the screw on the saddle. That´s common if you have a vintage bride, in that case you could file a groove in the bridge to keep the string from sliding onto the bridge screw
  12. Chritty
    Slacken the E and B strings. Turn the screw clockwise. Retune the whole guitar and see if it has made a difference. Keep a note on how many turns you have made, that way you can return the saddle to the previous height if it does not work.
  13. nashd
    nashd TDPRI Member
    59
    Oct 21, 2003
    Thanks very much. I did that. The threads are relatively coarse, so I could see the saddle moving even with 1/4 turn. I raised it by 1/4 turn, checked it, then raised it a further 1/4 turn (1/2 turn in total). It seems much better now. I've played it for a while, and I'm now hearing a very slight ringing on the B string, so tomorrow night I might raise that a fraction.
