String afterlength
Discussion in 'Tele Home Depot' started by Rocky creek, Jan 20, 2019.
  1. Rocky creek
    Rocky creek TDPRI Member
    Natchez MS
    Hello everybody new to the forum I had a question and I couldn't seem to find a thread about
    it. Should the string after length be parallel to the guitars centerline if designing a 6 in line fender style headstock. When you draw it out the strings actually run at a angle when getting to the headstock. If you drew them out long enough they would eventually run into each other. Just wondering I have seen people draw them out parallel to the centerline after the nut or does it really matter that much?
  2. guitarbuilder
    I never worried about it myself. I generally keep the general shape and hole placement regardless of nut spacing. I stick the string tree where you see them in factory photos.
  3. Freeman Keller
    Freeman Keller Tele-Afflicted
    Personally I think the important thing is to have a string path that doesn't run afoul of other tuners. If a string comes off of the nut at an angle I always give that slot a little radius so it is pointed at the tuner post. But sometimes they just go where ever they need to
  4. Rocky creek
    Natchez MS
    Just wondering in general if you want the least amount of friction at the nut what would be the best way to do it.
  5. Ronkirn
    Jacksonville, FL
    Rocky. Marty pretty much nails it... just look at the many other designs that all work just fine, with the strings running all over the place.... on a Fender types, if the string is a little askew, it's just not worth worrying about.
    rk
  6. Freeman Keller
    Some people seem to go to extremes to accomplish this, I believe that with a well made nut it isn't a problem.
    mfguitar likes this.
