Join TDPRI Today
Strat Trem setup?
Discussion in 'Tele Home Depot' started by KWhatley, Aug 25, 2013.
  1. KWhatley
    KWhatley Tele-Holic
    867
    Apr 13, 2013
    London, UK
    I rarely used my strat since buying it a couple of years ago now. Mainly because I also got a LP a week later and because I put .10's on it and threw out the setup (I was then reminded why I always prefered hardtails). I've started to re-set it up again today but it still needs some work and I wondered before I went much further if theres a "best way" to go about it?
    So far I've moved the rear springs and adjusted saddle heights to try and achieve the action I'd like. I've got the strings sitting 1.6mm off the 17th fret as per fenders blurb HERE. My trem is only raised by approx 2mm though and not 3.2 as per Fenders site and the intonations not done yet. I think that should be the last thing I do and until I'm happy everything is as it should be that will wait. I wouldn't say its staying perfectly in tune but then I've never used a trem system that did tbh
    So is there a "right way" to do this? or should I just set it up as above? It plays fine, though I've got some doubts about the neck pup atm but thats a separate issue.
    Also is there a "perfect trem angle"? So it would always raise say a tone and no further or tone and a half etc? or is that just purely personal control. May sound a stupid question but I've never really used a trem system much in over 20 years of twanging since my first main guitar was a hardtail strat :)
    Forgot to say its a 60's reissue heavy relic.
  2. DrBanana
    DrBanana Tele-Holic
    657
    Feb 22, 2011
    London
    Can't do a link cos I'm on my phone but there's a fairly fresh thread on the main Telecaster forum called Strat v Tele (or Tele v Strat, can't remember) and someone posted a vid regarding tension. i.e. string tension = spring tension
    Works well for me
  3. barbrainy
    barbrainy RIP
    Mar 2, 2012
    Northampton, UK
  5. rogb
    rogb Tele-Holic
    569
    Jan 3, 2012
    London, England
    By a strange coincidence, I decided to give the trem a go on my main jamming Strat this weekend. I always block off the trems with a small piece of wood, getting the springs nice and tight with the saddles about 2-3mm off the body.
    I thought if I glue that block in place in the cavity I can use the trem and it will return to solid position that I like.
    I lubed up the nut and saddles with Krytox (tiny amounts on the tip of a pin) and it worked brilliantly.
    Now I have a trem that I can use if needed but still has that rock solid, stable tuning and feel that I like.
    Got to say I played in a jam for about 4 hours last night and didn't feel the need to "vibe" at all, and stayed in tune all night, but it was good to know that after all these years I could if I wanted.
  6. MadJack
    MadJack Friend of Leo's
    Feb 18, 2012
    Candler, FL
  7. KWhatley
    KWhatley Tele-Holic
    867
    Apr 13, 2013
    London, UK
    Thanks for all the replies. I'll give the Carl V setup a shot and try and make it work with the action as I prefer it. I guess the height of the rear of the bridge from the body will be dictated but the intervals being as per his spec to once I have them right.
