Strat mod question
Discussion in 'Stratocaster Discussion Forum' started by Duncas, Jul 8, 2013.
  1. Duncas
    Duncas Friend of Leo's
    Nov 11, 2010
    Wolverhampton UK
    Hi guys,
    Iv got a Deluxe players strat, Amazing guitar, but yeah I really want it to sound like a les paul but at a whim back to sounding like a strat, Iv thought about HSH config but is this the best way to go?
  2. Edwin
    Edwin Banned
    828
    Jun 23, 2010
    Alaska
    I have that model of Strat and wouldn't change a thing. I also have a Les Paul but I don't play it, it is collecting dust at the moment. The LP's in my opinion are dull. I put a full size humbucker in the neck position of my Tele to get a LP sound but it just sounds like a Tele with a humbucker. Pedals, amps, pickups and guitars sound like what they are. No more, no less.
  3. waparker4
    Nov 9, 2011
    Philadelphia, PA
    I have a 3 single coil strat with a push/pull switch on the bridge tone (middle tone on a stock strat) that puts the bridge in series with whatever is selected on the switch
    It gives a bump in volume and rounder sound but still quite bright as it is the bridge pickup being added.
    Having done this I would suggest
    1. using a mini switch, the push pull is hard to engage
    2. Trying middle pickup in series with whatever, might get a thicker tone with mid+neck series which I can't get.
    With this mod the switch would be stock strat, or
    1. Neck + Mid series
    2. Mid 3. Mid 4. Mid
    5. Bridge + Mid series
  4. JoeNeri
    JoeNeri Friend of Leo's
    Mar 16, 2003
    Clarkdale, AZ
    Put a Dimarzio Pro Track in the neck. Great PAF tone in a dual-blade, single-coil size.
  5. Ringo
    Ringo Poster Extraordinaire
    Mar 16, 2003
    Memphis TN
    Get one of the Deaf Eddie Fat o Caster switches, it replaces a tone knob, you can get all kinds of different pickup combinations in addition to the stock 5. Series, out of phase etc...
    http://www.deaf-eddie.net/switches.html
    And he's a TDPRI regular too, though I haven't seen him post in a while.
  6. Duncas
    Nov 11, 2010
    Wolverhampton UK
    I have the mini toggle for the bridge in series, it comes stock on this strat model. I love the rest.
    is it just a pickup switch the fat-o-caster?
  7. erratick
    erratick Tele-Meister
    480
    Feb 11, 2013
    SoCal
    You are probably looking for a super start type pickup layout. Don't know if you need the floating trem as well.
    Not sure I'd mod into that these days, but if you do hum buckers in a single coil form factor in neck and bridge are the easiest. You can also just do one if you know what Les Paul sound you like- hss with the hum bucker at the bridge is fairly common.
    Coil tap switches allow you to turn the hum buckers to single coil. So you could do that as well.
    However nothing exactly does what you are asking- it just approximates- but you can get close. Especially if you use a modeling amp.
