StewMac Router Oops
Discussion in 'Tele Home Depot' started by Jake Nelson, May 22, 2019.
  1. Jake Nelson
    Jake Nelson Tele-Meister
    Bemidji, MN
    FYI drill your hole for the output jack AFTER you route for binding :rolleyes:
    was using this setup
    like my buddy caleb said a good craftsman could fix that and no one will ever know. we will see.
    Chuckster likes this.
  2. guitarbuilder
    I've done something just like that. :). I probably would take a forstner bit and make a perfect half circle out of it and then make a plug from the cut off scrap that was right in front of it. If you ensure the grain is going in the same direction and the plug is round, you'll just have a glue line. You have to make sure the end grain direction is the same too as well as the face grain.
  3. simoncroft
    simoncroft TDPRI Member
    Worthing, SE England
    That doesn't look a difficult grain to match – as it's close and regular – but an upsetting thing to happen. :(
  4. Jupiter
    Osaka, Japan
    This is a classic boo-boo; you are in good company! ;)
    I_build_my_own likes this.
  5. Fluddman
    Fluddman Tele-Meister
    Sydney, Australia
    Bummer. But something I confess to have done more than once.:oops:
  6. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    Never done binding, but just about every time on the round over process!
  7. mefgames
    mefgames Tele-Afflicted Platinum Supporter
    North Bay, Ca
    I like what guitar builder suggested. What is the entire body shape ? That looks like about a 1/4" gaff. Taking the binding into account, would it be possible to gracefully re-arc the shape of that portion of the body to eliminate the goof ?
  8. kafka
    kafka Tele-Afflicted
    Maryland
    OK, yeah, took me a minute to figure out what happened there. Yeah, oops. Well, short of not making mistakes in the first place, it's important to be able to recover from them.
  9. Jake Nelson
    Bemidji, MN
    @mefgames over all is
    but this is the inside before it was made smooth
  10. philosofriend
    philosofriend Tele-Holic
    Kalamazoo
    Not too hard to patch, if you were thinking about a sunburst now you have one more reason for it. Probably every one of us who has used a router on a guitar has made one of those .004 second horror-wacks. When I was a kid I built without power tools and I screwed up my instruments much more slowly.
    That is some great straight grain wood you've got there.
  11. mefgames
    North Bay, Ca
    Where is the chip ? This pic is before the binding rout. May be awfully tight if you tried to reshape the body to eliminate the error because of the cavities. I'd probably go with guitar builders fix. Good Luck.
  12. preeb
    preeb Poster Extraordinaire Vendor Member
    Sonoran Desert
    jack hole is the last thing I do on a body... it messes up the binding channels, body roundovers and the rim sanding
    Treadplatedual and Jupiter like this.
  13. Freeman Keller
    Freeman Keller Tele-Afflicted
    A nice edge 'burst hides all kinds of sins.
    Treadplatedual likes this.
  14. Old Deaf Roadie
    Old Deaf Roadie Tele-Holic
    Oregon
    Paint. Fixes everything.
  15. Peltogyne
    Peltogyne Tele-Afflicted
    Northern California
    I was amused at how nostalgic this was for me, one of my first real OMG what have I done mistakes. It was a roundover bit and not binding, but the same results.
    Memories :)
    Jupiter likes this.
  16. Jake Nelson
    Bemidji, MN
    the piece of cherry was thin because it was a backup incase i messed up the control cover so the bit would wander while trying to cut a plug so i clamped it between 2 pine 1 x 4’s. (hand drill, didn’t have a drill press handy)
    Treadplatedual and eallen like this.
  17. Jake Nelson
    Bemidji, MN
    oh and i did this before when i could use a press
    guitarbuilder and Treadplatedual like this.
