Starting a 1950 Broadcaster Relic
Discussion in 'Tele Home Depot' started by bferguson, Apr 15, 2013.
  1. bferguson
    bferguson TDPRI Member
    77
    Mar 9, 2013
    Atlanta, Georgia
    This is going to be an extension of my original post found here:
    http://www.tdpri.com/forum/telecast...722-building-52-tele-relic-neck-decision.html
    Started out think I would build a 52 Tele Relic. I have built several Strat relics in the past with good results.
    This will be my first Tele relic build.
    I purchase a Blackguard neck from Musickraft. It will probably be another month before I receive the neck from them.
    I purchased a vintage Tele body from Warmoth. It weighs just under 4 pounds.
    Very happy with the grain pattern of this body.
    I use liquid mask to paint the areas where the lacquer will be removed.
    Here are some pics of my progress:
  2. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    A few coats of butterscotch and clear lacquer with liquid mask areas removed.
    Still need to clean out some of the blue liquid mask.
    Now to let it cure for a month or two and into the deep freezer for some checking.
  3. stevenhay
    stevenhay Tele-Meister
    181
    Oct 9, 2010
    New Castle Indiana
    I like it. I wish I had the time and money now to do one like that. Shell Pink of course...
  4. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    Brodacaster Finally Completed
    Finally finished my Broadcaster build.
    List of parts
    Warmoth vintage Tele body
    Musikraft Blackguard custom made neck
    Kluson Deluxe single line tuners
    Klein Epic Broadcaster pickups
    Fender 52 RI with 0280 serial number stamped under logo
    JonesyBlues.com Broadcaster blender circuit
    Glendale Broadcaster knobs.
    Callaham Tele pickguard and string tree.
    All hardware aged either with Radio Shack etching solution or Muriatic Acid.
    GHS pure nickel strings.
    This is an amazing playing and sounding guitar
    I will post some videos of it this weekend.
  5. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    More pics
  6. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    Last pics
  7. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    Ok
    One more!
  8. R. Stratenstein
    R. Stratenstein Doctor of Teleocity
    Aug 3, 2010
    Loganville, Ga.
    Nice. Not usually much of a relic fan, but every so often I see something that's the exception to the rule--like your guitar. Great work.
  9. thecableguy
    thecableguy Friend of Leo's
    Looks well done. Not over done like a lot of relics.
  10. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    thecableguy, thanks. At first I was afraid I did too much relicing. I have more money in this thing that most of my other real Fenders. But it plays and sounds amazing! Going to try and make some videos of it soon.
  11. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    Usually when you build a parts guitar, you have do a lot of work adjusting the neck and sometimes even doing a fret level. I can't say enough about this neck from Musikraft. When I bolted it on and strung it up, it played almost perfectly right away. I didn't make a single adjustment to the truss rod. The only adjustments I made were on the bridge saddles for height and intonation. It plays like butter with no fret buzz anywhere!
  12. sjohnbruton
    sjohnbruton Tele-Holic
    901
    Aug 13, 2009
    Mobile, AL
    Looks great! Glad to hear it plays great, too.
    The liquid masking film is an idea I haven't seen before. How did you "age" the wood in the chipped away areas?
  13. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    sjohnbruton
    On the bare wood areas, I rubbed in some used motor oil, then finished with brown and black shoe polish. Also, after one of my workouts when my hands were sweaty, I rubbed the palms of my hands into the bare wood.
  14. jd0272
    jd0272 Tele-Meister
    219
    May 24, 2013
    Northumberland
    Looks very very nice BF. Neck wear (rear), care to expand?
  15. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    I had the idea several years ago when I did a Stevie Ray Vaughan Strat replica. I have seen so many guitars where the finish is chiseled out. That doesn't look like real paint chipping at all to me. When the paint comes off an old guitar, it leaves behind a fairly smooth raw wood surface unless there is a dent or scratch. On the SRV Strat, about 80% of the finish is gone. The only way I could think of to do that was with liquid mask, then finish the body as normal in sunburst. I will post some pics of the Strat to show how that came out. It works great!
  16. bferguson
    77
    Mar 9, 2013
    Atlanta, Georgia
    Here are some quick pics of the SRV Strat also done using liquid mask
  17. Greg M
    Greg M Tele-Holic
    857
    Sep 4, 2003
    Virginia
    Nice work there. Thanks for sharing :cool:.
