Spray Painting your guitar?
Discussion in 'Finely Finished' started by djt, Aug 4, 2006.
  1. djt
    djt TDPRI Member
    29
    Jul 23, 2006
    Minnesota
    It does sound crazy to me at first, but I keep reading that you can get a professional factory finish with high quality automotive spray paint. I bought an alder body and I have always like white bodys with rosewood fretboard combos. Surely somebody here has tryed this. Thanks for the help!
  2. MoOMaN2679
    MoOMaN2679 Tele-Meister
    168
    Sep 29, 2005
    Middlebourne, WV
    I did a Lake Placid Blue with the aerosol spray can's from ReRanch.com. I think it turned out fairly well, especially since it was a metallic color.
  3. djt
    djt TDPRI Member
    29
    Jul 23, 2006
    Minnesota
    Wow thats prrty!, is there anywhere that I can go without having to order it?
  4. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Oct 19, 2003
    Albuquerque, USA
    You can use Krylon and clear coat it with Deft. These are available at Walmart.
  5. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    You're lucky to have an alder guitar, that wood is not supposed to need much surface prep before painting.
    You can get a good finish with anything you can apply evenly, clearcoat and sand easily.
  6. TELEkinetic
    TELEkinetic Tele-Holic
    613
    Jun 11, 2005
    Central Arkansas
  7. Ronkirn
    May 1, 2003
    Jacksonville, FL
    Autimotive Spray paint... Oh No.....
    Didja know, the in the good 'ol days, Leo used automotive finishes on the guitars, DuPont Duco (nitrocellulose) and DuPont Lucite (acrylic lacquer) were the finishes of choice.
    Today, you can take the old DuPont finish codes to a good automotive finish supplier and he can match it up with an inexpensive modern equivalent, about 15 bux a pint.
    Or if you can get a color swatch, the Sherwin Williams Chemical Coatings distributors can match it with Nitrocellulose Lacquer at about 25 bux a gallon.
    Automotive finishes cover MUCH better than the typical lacquers and enamels available in spray cans, so one pint will easily do the color coat on 4 - 6 bodies.
    After allowing it to dry completely (about 2 weeks) you can start applying a clear coat.
    Still having fun, and practicing, how 'bout you.
    Ron Kirn
  8. mvmsl2
    mvmsl2 TDPRI Member
    I used DupliColor basecoat and clear when I build my sister's strat, rattle cans from Pep Boys. The key to it as always is a very patient prep, and even more patient wait time for the paint to harden (its extremely tempting to start compounding and polishing as soon as that clear feels hard!) Now her guitar looks like a 99 Dodge Neon Alpine Green Pearl!
    dave_b likes this.
  9. teleman65
    teleman65 Tele-Holic
    936
    Jun 22, 2006
    Do you have a picture?
  10. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
    I've used Krylon, Rust-O-Leum, and Lowes house brand for my color coats. I like Krylon the best because it drys faster. Krylon is an acrylic lacquer. I don't know about the others. Ace Hardware's house brand is made by Krylon and has colors not found in the Kylon brand. I recently picked up some DupliColor copper metallic from Pep Boys. I think I'll use it to do a matching headstock on something. The point is, if you don't have to have an actual Fender color, you can get your paint locally. Clear coat with Deft gloss ......... it is a nitrocellulose lacquer. You'll save money.
    Here are three little Ferden Minis.
    ........[​IMG]
  11. mvmsl2
    mvmsl2 TDPRI Member
    I'll have to have her take some more pics for me. That's the only one I took. She took possession of it the day I finished up the string trees and put a custom logo on it.
  12. aznrambo481
    aznrambo481 Friend of Leo's
    Did you buy aerosol spray cans, or just get regular paint and spray it? If you got regular paint, do you have to thin it down before you spray it?
  13. Jack Wells
    Oct 19, 2003
    Albuquerque, USA
  14. Aen
    Aen Tele-Holic
    943
    Nov 7, 2004
    Eau Claire, WI
    +1. Except i haven't gotten to the clear coat yet. I did it right over a Sage green metallic finish, I'm waiting for more black paint to wear off, so I can have TEH RELICZ!
  15. djt
    djt TDPRI Member
    29
    Jul 23, 2006
    Minnesota
    Also, is it just aerosol primer under the paint?
  16. Ronkirn
    May 1, 2003
    Jacksonville, FL
    The DupliColor grey primer available at most auto parts shops is an acrylic lacquer, rapid filling and very easy to sand... a few coats will fill just about any grain.
    Adding a color coat, Krylon works great, after about a good week of drying to be sure the solvent is gone to prevent chemical incompatibility problems (ugly), is quick and easy... again allow a lot of time to dry because Krylon and Deft are not compatible unless the base coats are completely dry. . . as in devoid of their solvents. Deft is Nitrocellulose too. Test it by applying pressure with a fingernail in a concealed place like under the pickguard. If you can easily make a dent.. it ain’t ready…
    If you put down a couple of coats of Deft Satin, start with very light coats with good drying time between then proceed to a couple of good wet coats. It will sand very easily... then finish with a few clear gloss coats.. now allow it to dry a Looooong time to harden... then proceed to the wet sanding and polishing stage...the longer you wait to let it harden the better the finish will be.. I’m talkin’ weeks and/or months here… you will have an awesome finish.. and not that far removed from the color finishes of the '62 Fenders.
    Ron Kirn
  17. djt
    djt TDPRI Member
    29
    Jul 23, 2006
    Minnesota
    Does anybody have a pic of a natural finished alder body? Does anybody do that with alder?
  18. TELEkinetic
    613
    Jun 11, 2005
    Central Arkansas
    Here is the back shot of my Maple capped Alder body.
    I purposely left the grain unfilled as Rod DiStefano suggests in his website.
    Check out the "info" page.
    http://208.56.238.182/
    Here's the front in case you are curious.
  19. RichardWitt
    RichardWitt Tele-Afflicted
    Aug 1, 2006
  20. jpkusa
    jpkusa Tele-Holic
    585
    Dec 18, 2004
    Nowhereseville
    Workspace for spraying?
    I've been mulling over the notion of trying my hand at this for a while. Problem is, I don't have a garage. There's a small tool shed behind the house, but it's not humidity-controlled, and I live in the most humid city in America, practically. Plus it's pretty dusty and dirty in that shed. Any ideas on where to spray a body? Can you spray outside and bring it in to dry, or will it be too fume-y?
