speaker fit and rattling components within the chassis questions
Discussion in 'Glowing Bottle Tube Amp Forum' started by 2after909, Mar 1, 2013.
  1. 2after909
    2after909 Tele-Meister
    491
    Dec 23, 2010
    brooklyn, ny
    a couple days ago i bought a 1960 gibson lancer ga-6. sounds good.
    the amp still had the original jensen speaker, but it farted out pretty bad with low notes so today i replaced it with a warehouse reaper. the back of the reaper speaker is much wider than the original speaker though, and causes one of the tubes to be pushed over to the side slightly so that it's not straight. the tube is also touching the back of the speaker. this worries me. i feel like it might not be ok like this. anybody have any thoughts about this?
    the amp has the original tubes still in it. rca raytheons.
    also, the individual parts of the amp's head, within the chassis, are rattling in there when it's played through. is there a good, safe way to secure these parts so they're not rattling around?
  2. Tellebelly
    Tellebelly TDPRI Member
    No matter how you slice it, that doesn't sound like a very good situation. I had a similar problem mounting a Weber 12 alnico in a 1342 Silvertone. I was able to drop the speaker mounting board down 12mm, and then the speaker cleared the components.
  3. telex76
    telex76 Doctor of Teleocity Silver Supporter
    Jun 24, 2006
    Fort Worth,Tx.
    I wouldn't play it with the speaker like that, just because.
    Rattling components need to be looked at. Change old electrolyitcs, push parts slightly away from each other so they aren't touching. As a last resort you could put a little silicon gel where its rattling, but I don't like doing that.
  4. 2after909
    491
    Dec 23, 2010
    brooklyn, ny
    yeah, i guess i shouldn't play it like this. i'll have to remove that speaker and either move it within the cabinet, so it's clear of the tube, or return it and swap it for one that will fit.
  5. 2after909
    491
    Dec 23, 2010
    brooklyn, ny
    i guess i need to also figure out some way to anchor those parts down so they're not being vibrated around and making all that racket.
