Soundhole Pup Question
Discussion in 'Acoustic Heaven' started by Wop Geronimo, Jan 3, 2013.
  1. Wop Geronimo
    Wop Geronimo Former Member
    597
    Jul 19, 2006
    Confusion, USA
    I bought a Duncan woody. Sounds great. My question is this. I want to make it a permanent fixture in the guitar. My thought is to cut and splice the cord running it inside the guitar and wiring it to an input jack. And of course mounting the Jack at the back of the guitar. Will this work and do you guys foresee any stumbling blocks?
    Thanks in advance for any help.
  2. still_fiddlin
    still_fiddlin Friend of Leo's Ad Free Member
    May 6, 2009
    I did that a while back. I added a jack/plug inside, secured with velcro, so the PU can be removed/replaced if I ever decided. (Decided, instead, to get a new guitar with built-in electronics :)).
    The jack is the hard part. I'd do some searching and see how folks have done that (without wrecking their guitars), and make sure your forearm can fit through the soundhole to reach to where you plan to have it come through, so tightening is possible.
  3. Wop Geronimo
    597
    Jul 19, 2006
    Confusion, USA
    Thanks for the pics and info. It's not a real expensive guitar. Just one I like a lot. I don't mind making a hole :)
  4. lonnieboy
    lonnieboy TDPRI Member
    5
    Aug 24, 2012
    You don't need to get your arm inside your guitar to install a jack. A 1/4 inch length of surgical tubing poked through the drilled hole grab it out of the sound hole stick the jack into it attach all the wires and just pull it back through the drilled hole screw the nut on a "Voila". That's the way electronics are installed in F hole type guitars. There's a real good demonstration on youtube
  5. syrynx
    syrynx Tele-Afflicted
    Possible stumbling blocks:
    Be sure the OUTPUT jack can be tightened from the outside, like this one or this other one. Not all of them can be, and in some instances you will indeed need to stick your hand through the sound hole to secure a retaining nut on the inside. Voice of experience here: It ain't easy.
    You can solder the cable from the pickup directly to the jack. I did this with two Lawrence Sound Research pickups in two Martins, thirty-plus years ago.
    You can solder a mini plug (1/8" or 3mm) onto the cable from the pickup, and solder a mini jack to the terminals of the OUTPUT jack/strap pin. I did this with an Ovation, thirty years ago. This permits easy pickup swapping, should you desire to do so. But it requires sticking your hand through the sound hole to connect the pickup's mini plug to the mini jack.
    You can solder a mini plug onto the cable from the pickup, solder a short cable to the OUTPUT jack, solder a mini jack onto the end of the cable, and connect that way. On one guitar, I mounted the mini jack through a small block of wood, which was then glued to a top brace near the sound hole. On another, I left the mini jack flopping around inside the guitar body, and wrapped and taped a sponge around it to keep it from rattling. Either of these methods permits quick pickup changes without reaching around blindly inside the guitar's body. Still_fiddlin's Velcro solution is more elegant than my sponge, and easier to implement than the permanently mounted mini jack. It's probably the best choice.
