Solid State Amp Advice Please..
Discussion in 'Amp Central Station' started by Texicaster, Apr 12, 2019.
  1. Texicaster
    Texicaster TDPRI Member
    Arizona
    Hi,
    Play my '58 AVRI straight through a '65 Princeton RI issue and love the subtle growl!
    I'm going on the road for an extended period and would like some advice on a smaller than the Princeton solid state amp that will handle road abuse. I don't gig or anything; maybe hook with some firends along the way.
    Not so much interested in the minis like Blackstar Fly or Roland Cube... something a step above that can give me the Tele tones like the PRI
    Want to keep price below $500 which should open up plenty of options. Could even spend a bit more if some killer option.
    I'm from the "buy the best and cry once" school of thought and not looking for a bargain as much as tone!
    Thanks!
    Texacaster
  2. bftfender
    bftfender Friend of Leo's
    York PA
    my new thing is..get a few in the range..use your main amp to set your must have tones that you already have. Keep what works. A/b everything..don't go off of memory & def set the tone you are used by directly using your main amp. nothing gets lost & no compromise..no amount of videos or internet opinions will work..real live use with the guitar you use the way you play. Don't be afraid to try a few to get desired result,
  3. ricardo1912
    ricardo1912 Tele-Afflicted
    Kent, UK
    Mustang Gt100 might be a good bet. Lightweight, gets some really nice tones, especially Fender ones. Just needs a bit of tweaking but then you're good to go.
    OlRedNeckHippy likes this.
  4. D_W_PGH
    D_W_PGH Friend of Leo's
    Pittsburgh
    Not sure if a bandit will get you exactly there, but assuming you're looking to try something in person:
    * hit up the marshall solid state amps and drop the mids. They're surprisingly good with their gain set on the edge of break up and the mids scooped (talking about the simple older ones - know nothing about newer ones) and sound good with pedals.
    * fender's princeton chorus and ultra chorus amps were always wonderful to me. I gigged with a princeton chorus when I was young and never used any pedals. It had a good clean channel and in an 80s way, a good middle of the road second gain channel. They aren't something you'd repair, but I see the ultra chorus (2x12 combo) for sale from time to time locally for $150 or so.
    I'm sure there are a million others, but those two types are simple and cheap.
    FenderGuy53 and Bruxist like this.
  5. perttime
    perttime Tele-Afflicted
    Finland
    Try the Roland Blues Cube series. The big ones are big but the "Hot" models are more handy.
  6. Chicago Slim
    Chicago Slim Tele-Afflicted
    Bowling Green, KY
    Try the:
    Boss Katana 50
    Roland Blues Cube Hot
    Boss Nextone 40
    Fender SCXD/X2
    I've tried the Fender Champion 30 DSP, and it didn't work for me. Peavey Bandits and Studio Pro's are bigger and heavier than a PRRI.
  7. OlRedNeckHippy
    OlRedNeckHippy Friend of Leo's
    South Jersey (Atco)
    A buddy of mine, that uses a Hot Rod Deluxe in full band, uses a Mustang 100 in his Duo with his wife. He has nothing but good comments on the Mustang. Loves it.
  8. SolidSteak
    SolidSteak Friend of Leo's
    My recommendations in order from good/$$$ to not great/cheaper:
    1) Quilter 101 Mini Reverb. This one you'd have to buy or make a cabinet for, but I was surprised at how close this guy got it to sound like a Princeton:
    2) Tech 21 Trademark 10, or Trademark 30. 10" speaker, doesn't sound like your 65 Princeton but you can get plenty of good sounds out of it.
    3) A Fender Frontman 25r might be a small enough, cheap enough clunker to take on the road. You can get a decent clean tone out of them, and the reverb is passable. And if it breaks you're only out $60-$100 or so (depending on how cheap you can find one for.) A Fender Sidekick Reverb 25r is even better if you can find one.
    Rich724, intrentnet7 and Jimmy Dean like this.
  9. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Cab sim capability in the Joyo
  10. wulfenganck
    wulfenganck Tele-Holic
    Seligenstadt, Germany
    Peavey has some nice solid state amps - I bought an Express for 80,- Euro, nice clean, acceptable crunch, loud enough for rehearsals and small clubs.
    intrentnet7 and Telecastoff1 like this.
  11. Grateful Ape
    Grateful Ape Tele-Holic
    I can vouch for the Deluxe 112+
    Twang Deluxe and Tony474 like this.
  12. BigDaddyLH
    Kelowna, BC, Canuckistan
    interesting that, in order to come close to the Princeton, he was cranking the mids on the Quilter. What happened to scooped mids?
  13. D_W_PGH
    Pittsburgh
    I wonder if the quilters are too versatile (leading to more fidget time to find out where you feel like they're dialed in) - I have one (mini reverb) I'm about to turn over. I'll admit I haven't given it as much time as I should so far, but also don't want to have to change settings all the time. Interesting thing to try, and very small, but after fiddling with it a little bit and then playing a peavey classic head and a marshall reverb 12, the latter two seemed so much easier to dial in.
    On the plus side, it'll probably cost about $10 to ship when I dump it, and I won't have the UPS guy bugging me about whether or not it's over 70 pounds.
    tonyguitargoat likes this.
  14. albatros
    albatros TDPRI Member
    ITALY
    Peavey Bandit 112 transtube. Very close to my Princeton Reverb and even better.
    FenderGuy53 likes this.
  15. SolidSteak
    I think it has something to do with the Mid control on the 101 Reverb being an active cut/boost. So when it's straight up, that's flat, not halfway up.
    D_W_PGH likes this.
  16. SolidSteak
    They are definitely not plug-and-play amps from my experience, with the exception of their older "Tri-Q" amps like the Tone Block 200 and 201.
    D_W_PGH likes this.
  17. USian Pie
    USian Pie TDPRI Member
    North Texas
    For nice subtle growl in a small solid state amp, I would probably start with a Blues Cube Hot.
  18. SolidSteak
    There is a used Blues Cube Hot at a store close to where I live that's $350... I kind of want to try it but I already have too many amps.
  19. BigDaddyLH
    Too many amps? Too much fun? Too happy? Too much lovin'?
    Sorry, I don't comprehend.
    SolidSteak and Grateful Ape like this.
  20. Telecastoff1
    Telecastoff1 Tele-Meister Silver Supporter
    Minnesota
    Peavey Special 130. Proven to be ultra-reliable and easy to get your own sound dialed in. These amps continue to be used and seen on stages all over the world by the most demanding pros who won't settle for less in a Solid State amp. :)
