Size zero debate - How thin is too thin?
Discussion in 'Tele Home Depot' started by Hutchwearing6, Oct 29, 2015.
  1. Hutchwearing6
    Hutchwearing6 TDPRI Member
    If I can get it cauled and glued I will probably try to finish the neck shaping, which I have done by hand in the end (spokeshave/facets) and the plan is to do an endpin jack drilled through to the pickup cavity and around to the control cavity.
    Perhaps I can hide the worst of it with the scratchplate.
  2. Hutchwearing6
    I may have learned some lessons about routing, but do put me straight if you disagree:
    My templates are 18mm ply- and I have template router bits at about 20mm and 50mm lengths. Ideally I'd do the whole thing on the 20mm bit in short passes, but ended up using the long bit owing to thickness of router table and a short collet. On today's evidence I'm thinking yes to shallow passes and yes to finding a collet extension if I can
    crazydave911 likes this.
  3. Hutchwearing6
    Bit o' titebond, many clamps, sanding drum and CONSIDERABLY MORE PATIENCE SHOWN henceforth...
  4. Hutchwearing6
    Finally a picture showing my thinking with the neck. Accepting that looking plausible is still a long way from being playable, I expected this should be most of the neck shaping complete. Happy with the blends, mostly.
  5. Hutchwearing6
    Scratchplate is almost complete, and wood dye in the mail for staining the fretboard ebony. At which point, will post a mock up picture
  6. Ripthorn
    Ripthorn Tele-Afflicted
    Austin, TX
    You are correct about routing lessons: take a little at a time, don't climb cut, etc. Ron Kirn has a fantastic tutorial here on the forum somewhere on it. Keep up the good work.
  7. Hutchwearing6
    Partial mock up, eventually. Needed quite a bit more attention on the back of the neck to get a constant thickness and work in the blends a bit better.
    Ebony colour wood dye into the fretboard, having slotted it throughout. I am ever so slightly minded to try a wide drill point through the dye instead of trying to install fret markers.
    Believe next job will be finishing before fretting and wiring. Thinking it's a grain filler and then an oil finish, since I mostly like the wood grain and that'll look good with the through-neck?
    Steveinthesticks likes this.
  8. ppg677
    ppg677 Tele-Meister
    WI
    Just sandwich the 25mm wood to form 50mm?
    EDIT: oops...didn't realize it was a super old post
  9. DrASATele
    North of Boston
    Brainy would be proud that you never gave up and are still at it, he was the King or re-fin.
