Join TDPRI Today
simple newbie question: wire pickup directly to output jack
Discussion in 'Just Pickups' started by WrayGun, Dec 23, 2009.
  1. WrayGun
    WrayGun Tele-Afflicted
    May 5, 2006
    Pittsburgh, PA
    Well, the subject pretty much says it all: I'm thinking of wiring a stock Mexican Tele neck pickup straight to an output jack and throwing the whole mess into an old cheapo acoustic archtop that I'm using for slide.
    So, my questions are: will it work without volume/tone controls? There will just be a hot wire and a ground wire, right? Any reason not to do it? I'll be using it mostly for recording.
  2. sjtalon
    sjtalon Poster Extraordinaire
    >So, my questions are: will it work without volume/tone controls? There will just be a hot wire and a ground wire, right? Any reason not to do it? I'll be using it mostly for recording. <
    Yep that will work just like you're planning it.
  3. WrayGun
    May 5, 2006
    Pittsburgh, PA
    OK, one more stupid question: Just to confirm what I think, the the ground is the black lead and the white is the hot lead, right?
  5. bradpdx
    bradpdx Friend of Leo's
    Jul 16, 2006
    Portland, OR
    Yep. Give it a try and see what it does! You can always add controls later if you choose.
  6. sjtalon
    RIGHT ON !! 100%
    Ya know what I like about stupid questions ?
    They are easy to answer !!! :p
    Let us know how you make out.
    Happy Holidays
  7. WrayGun
    May 5, 2006
    Pittsburgh, PA
    Thanks everyone! I now have a good holiday project to keep me off the streets. Merry Holidays to all of you :)
  8. WrayGun
    May 5, 2006
    Pittsburgh, PA
    it works!
    Well, I put it all together after dinner this evening, and much to my surprise, it works really well! See photos below of my incredible craftsmanship.
    It does have a fairly noticeable single-coil buzz though. Think shielding around the bottom of the pickup, where the windings are exposed, would help?
  9. otterhound
    otterhound Poster Extraordinaire
    Dec 14, 2008
    Manheim Pa.
    Add a good volume pedal and you just mat have something sweet . Merry Christmas to you and your Airedales !
  10. GuitarSimen
    GuitarSimen TDPRI Member
    7
    May 6, 2010
    Norway
    The output jack thing has 3 soddering posts (i dont know what its called) and two of them are for the wiring from the pickup. Right? so the last one is for no use when we attach the pickup directly to the output jack?
  11. Ben Harmless
    Ben Harmless Friend of Leo's
    Mar 10, 2003
    Allston, Mass
    Three solder lugs usually indicates either a switching jack, or a balanced jack. If using just the single pickup, then you'd just use whichever two contacts are going to be touching the proper parts of the plug when it's inserted - and usually with a balanced jack, that can mean either of the sleeve contacts as well as the tip contact.
    I don' t know if that made any sense, but welcome!
    ...And Bad Porc, that looks great! I'm jealous!
  12. GuitarSimen
    7
    May 6, 2010
    Norway
    im thinking of using a Piezo Transducer and solder that to a jack output. would that work?
  13. Blank
    Blank TDPRI Member
    84
    Dec 17, 2009
    Burnaby, Canada
    YAY for thread hijack! anyways, yes, you can use a piezo transducer as a pickup. You need pretty good contact to sound good with one of those.
  14. GuitarSimen
    7
    May 6, 2010
    Norway
    ok. thanks
  15. GuitarSimen
    7
    May 6, 2010
    Norway
    but if I want to remove a pickup from a strat. which pickup are the easiest one to remove?
  16. donh
    donh Tele-Afflicted
    Apr 25, 2010
    Oh Aich Ten
    whichever one you get to first as you dissassemble the guitar!
  17. GuitarSimen
    7
    May 6, 2010
    Norway
    ok
  18. Ronsonic
    Ronsonic Tele-Afflicted
    you'll want to take out the coin, the actual piezo sandwich in there and super glue it to the top. Probably on the inside would look neater :eek:
  19. GuitarSimen
    7
    May 6, 2010
    Norway
  20. GuitarSimen
    7
    May 6, 2010
    Norway
    well that did'nt work. if you want to see the pictures just add me on facebook and see the pictures under album: meck meck.
    my name: Simen Grøneng Johansen
